Extend the distance between a computer and a USB 3.0 device by an additional 5 meters. The USB3AAEXT5M, 5-meter Active USB 3.0 Extension Cable, offers one USB type-A (male) connector and one USB type-A (female) connector, and provides an active extension of USB 3.0 devices of up to 5-meters (16-feet). An all in one cable for overcoming distance restrictions as well as power source limitations; the active USB 3.0 extension cable incorporates bus powered active circuitry to ensure performance beyond the length limits of standard USB cables. Up to 4 of these cables can be daisy-chained together, allowing the connection to be extended a total of 20-meters. If necessary, the USB device can be powered from a wall outlet using the Universal AC power adapter provided with the cable. The USB3AAEXT5M extension cable (USB Extender) supports high speed USB 3.0 transfer rates of up to 5Gbps.
- StarTech.com 16.4ft Active USB 3.0 Extension Cable with AC Power Adapter - Shielded - Male to Female USB USB 3.1 Gen 1 Type A (5Gbps) Extender (USB3AAEXT5M) - USB extension cable - USB Type A to USB Type A - 5 m
- Active cable (signal regeneration)
- Length
- 5 m
- Connector
- 9 pin USB Type A - male
- Connector (Second End)
- 9 pin USB Type A - female
- USB / USB 2.0 / USB 3.0
- Black
- 2-year warranty
- Designed For
- P/N: PEXUSB3S2EI, PEXUSB3S42, PEXUSB3S42V, PEXUSB3S44V, PEXUSB3S7, ST7300U3M, ST7300USB3B, SVA5H2NEUA, USB3SAA3MBK
- Plated Connector
- Nickel
- Length
- 5 m
- Black
- Connector
- USB / USB 2.0 / USB 3.0, FCC, RoHS
- 2-year warranty
- Designed For
StarTech.com 3m USB 3.0 Active Extension Cable - M/F | In Stock | £76.67 |
StarTech.com 5m USB 3.0 Active Extension Cable - M/F | In Stock | £76.96 |
StarTech.com 10m USB 3.0 Active Extension Cable - M/F | In Stock | £109.06 |
StarTech.com 3m 10ft USB 3.0 A to A Cable | In Stock | £7.94 |
