OS2 SC to SC Single Mode Duplex Fiber Optic Patch cable facilitates connectivity across 40G/100G networks. It supports Coarse Wavelength Division Multiplexing (CWDM) across an extended wavelength range of 1260-1625nm, improving channel isolation for optimal signal strength over long distances.
                CompatibilityThis 9/125µm Single Mode fiber cable supports 1260-1625nm laser-optimized sources and is ideal for critical connections between servers, switches, and data center equipment. It is backward compatible with OS1 networks, ensuring a reliable connection in legacy fiber environments.
                Engineered for Optimal PerformancePrecision-manufactured ceramic ferrules ensure accurate fiber alignment for an insertion loss below 0.3dB. Ultra Physical Contact (UPC)-polished SC to SC fiber ends greatly improve return loss characteristics over older PC polishing techniques. The Bend Insensitive Fiber Core is surrounded by a layer of low refractive index material. This material reduces the amount of light that can escape the fiber cable by reflecting the light back into the fiber. The OS2 fiber patch cord is engineered for low attenuation and performance that exceeds ITU-T G652.D/G657.A1 and IEC60703-2-50 type B1.3/B6.a1 industry standards.
                LSZH Cable JacketHoused in a Low-Smoke Zero-Halogen (LSZH) flame-retardant jacket, the OS2 fiber cable emits low smoke and toxic fumes when exposed to extreme heat or in the event of a fire. This enables safer cable installations in areas with poor ventilation including some industrial settings, self-contained environments such as trains and aircraft, as well as residential settings where compliance with building codes must be considered. Each OS2 fiber cable is individually tested for insertion loss performance and includes a test report, for guaranteed compatibility and 100% reliability.
- StarTech.com 5m (16.4ft) SC to SC (UPC) OS2 Single Mode Duplex Fiber Optic Cable, 9/125µm, Laser Optimized, 40G/100G Zipcord, Bend Insensitive, Low Insertion Loss - LSZH Fiber Patch Cord (SMDOS2SCSC5M) - patch cable - 5 m - yellow
- Patch cable - OS1/OS2
- Technology
- Duplex fibre optic
- Type of Fibre Optics
- Singlemode
- Halogen-free, ceramic ferrule, bend insensitive, low insertion loss, bending radius 10mm, aramid fibre reinforced, up to 100 Gbps, 0.3 dB insertion loss, 55 dB return loss, wavelength of 1260-1625 nm, Coarse Wavelength Division Multiplexing (CWDM) support
- Length
- 5 m
- Diameter
- 2 mm
- Core / Cladding Diameter
- 9 / 125 micron
- Connector
- 2 x SC/UPC single-mode - male
- Connector (Second End)
- Yellow
- Limited lifetime warranty
- Network Cable Type
- Technology
- Singlemode
- Jacket Material
- Low Smoke Zero Halogen (LSZH)
- 9 / 125 micron
- Length
- 5 m
- Diameter
- 2 mm
- Yellow
- Connector
- WEEE, EMI
- Shipping Width
- 22 cm
- Shipping Depth
- 20 cm
- Shipping Height
- 0.47 cm
- Shipping Weight
- 55.3 g
- -20 °C
- 60 °C
