StarTech.com 5m SC to SC OS2 Fiber Cable
Quicklinx: HMPLWS00 Mfr#: SMDOS2SCSC5M
Length: 5m
Colour: Yellow
20 In Stock
£19.67 ex VAT
£23.60 inc VAT
OS2 SC to SC Single Mode Duplex Fiber Optic Patch cable facilitates connectivity across 40G/100G networks. It supports Coarse Wavelength Division Multiplexing (CWDM) across an extended wavelength range of 1260-1625nm, improving channel isolation for optimal signal strength over long distances.
  • Compatibility
    This 9/125µm Single Mode fiber cable supports 1260-1625nm laser-optimized sources and is ideal for critical connections between servers, switches, and data center equipment. It is backward compatible with OS1 networks, ensuring a reliable connection in legacy fiber environments.
  • Engineered for Optimal Performance
    Precision-manufactured ceramic ferrules ensure accurate fiber alignment for an insertion loss below 0.3dB. Ultra Physical Contact (UPC)-polished SC to SC fiber ends greatly improve return loss characteristics over older PC polishing techniques. The Bend Insensitive Fiber Core is surrounded by a layer of low refractive index material. This material reduces the amount of light that can escape the fiber cable by reflecting the light back into the fiber. The OS2 fiber patch cord is engineered for low attenuation and performance that exceeds ITU-T G652.D/G657.A1 and IEC60703-2-50 type B1.3/B6.a1 industry standards.
  • LSZH Cable Jacket
    Housed in a Low-Smoke Zero-Halogen (LSZH) flame-retardant jacket, the OS2 fiber cable emits low smoke and toxic fumes when exposed to extreme heat or in the event of a fire. This enables safer cable installations in areas with poor ventilation including some industrial settings, self-contained environments such as trains and aircraft, as well as residential settings where compliance with building codes must be considered. Each OS2 fiber cable is individually tested for insertion loss performance and includes a test report, for guaranteed compatibility and 100% reliability.
StarTech.com 5m (16.4ft) SC to SC (UPC) OS2 Single Mode Duplex Fiber Optic Cable, 9/125µm, Laser Optimized, 40G/100G Zipcord, Bend Insensitive, Low Insertion Loss - LSZH Fiber Patch Cord (SMDOS2SCSC5M) - patch cable - 5 m - yellow
Patch cable - OS1/OS2
Duplex fibre optic
Type of Fibre Optics
Singlemode
Halogen-free, ceramic ferrule, bend insensitive, low insertion loss, bending radius 10mm, aramid fibre reinforced, up to 100 Gbps, 0.3 dB insertion loss, 55 dB return loss, wavelength of 1260-1625 nm, Coarse Wavelength Division Multiplexing (CWDM) support
Length
5 m
Diameter
2 mm
Core / Cladding Diameter
9 / 125 micron
Connector
2 x SC/UPC single-mode - male
Connector (Second End)
Yellow
Network Cable Type
Duplex fibre optic
Singlemode
Jacket Material
Low Smoke Zero Halogen (LSZH)
9 / 125 micron
Length
5 m
Diameter
2 mm
Yellow
Connector
WEEE, EMI
Shipping Width
22 cm
Shipping Depth
20 cm
Shipping Height
0.47 cm
Shipping Weight
55.3 g
-20 °C
60 °C
Length: 5m
Colour: Yellow
