Make Power-over-Ethernet-capable Gigabit network connections. The N6PATC5MRD Cat 6 Patch Cable (5m) meets or exceeds all Category 6 cable specifications to ensure reliable Gigabit network connections, and features a durable red PVC jacket that enables you to color code your network cable runs as needed.
To ensure long-lasting performance, this high quality Cat 6 patch cable features a snagless design that protects the RJ45 connector clips from damage and makes the cable less prone to snagging during installation. The cable also features molded PVC strain relief that prevents the RJ45 connector termination points from bending at sharp angles, reducing the risk of cable failure.
Constructed of only top quality materials, this Cat 6 Patch Cord delivers reliable performance.
Get the highest value for your cable investment with the Cat 6 cables, each one manufactured using high-quality copper conductors.
Rely on the RJ45 connectors to deliver optimum conductivity while eliminating signal loss due to oxidation or corrosion.
Reliable construction
The cable is made with a PVC jacket that provides durability and protection against wear and tear, ensuring long-lasting use in both home and office environments. -
Improved data transmission
With 4 pairs of twisted wires and minimized Near-End Crosstalk, this cable supports high-speed data transfer, making it suitable for both standard and high-bandwidth applications. -
User-friendly design
The snagless feature allows for hassle-free handling and installation, minimizing the chances of connectors snagging during placement, making setup quick and easy. -
Versatile connectivity
Featuring male RJ-45 connectors on both ends, this cable easily connects to routers, switches, and other networking equipment, ensuring compatibility across various setups.
- StarTech.com 5m CAT6 Ethernet Cable, 10 Gigabit Snagless RJ45 650MHz 100W PoE Patch Cord, CAT 6 10GbE UTP Network Cable w/Strain Relief, Red, Fluke Tested/Wiring is UL Certified/TIA - Category 6 - 24AWG (N6PATC5MRD) - patch cable - 5 m - red
- Patch cable - CAT 6
- Technology
- Wiring Scheme
- T568B
- Snagless, minimised Near-End Crosstalk (NEXT)
- Length
- 5 m
- Connector
- RJ-45 - male
- Connector (Second End)
- RJ-45 - male
- Red
- Limited lifetime warranty
- Network Cable Type
- Technology
- Wiring Scheme
- T568B
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 24
- Pairs per Cable
- 4 pairs
- Plated Connector
- Gold
- Length
- 5 m
- Red
- Connector
- RJ-45 - male
- RJ-45 - male
- RoHS, ETL
StarTech.com 5m Blue Gigabit Snagless RJ45 UTP Cat6 Patch Cable | In Stock | £6.82 |
StarTech.com 5m Black Gigabit Snagless RJ45 UTP Cat6 Patch Cable | In Stock | £6.98 |
StarTech.com 5m Gray Gigabit Snagless RJ45 UTP Cat6 Patch Cable | In Stock | £8.24 |
StarTech.com 5m Orange Gigabit Snagless RJ45 UTP Cat6 Patch Cable | In Stock | £7.05 |
StarTech.com 5m Red Gigabit Snagless RJ45 UTP Cat6 Patch Cable | In Stock | £8.00 |
StarTech.com 5m Green Cat6 Patch Cable | In Stock | £7.13 |
StarTech.com 5m Purple Cat6 Patch Cable | In Stock | £7.13 |
