StarTech.com 5m Red Gigabit Snagless RJ45 UTP Cat6 Patch Cable
Quicklinx: 9J55WS00 Mfr#: N6PATC5MRD
Length: 5m
Colour: Red
More than 50 In Stock
£7.84 ex VAT
£9.40 inc VAT
Make Power-over-Ethernet-capable Gigabit network connections. The N6PATC5MRD Cat 6 Patch Cable (5m) meets or exceeds all Category 6 cable specifications to ensure reliable Gigabit network connections, and features a durable red PVC jacket that enables you to color code your network cable runs as needed.
To ensure long-lasting performance, this high quality Cat 6 patch cable features a snagless design that protects the RJ45 connector clips from damage and makes the cable less prone to snagging during installation. The cable also features molded PVC strain relief that prevents the RJ45 connector termination points from bending at sharp angles, reducing the risk of cable failure.
Constructed of only top quality materials, this Cat 6 Patch Cord delivers reliable performance.
Get the highest value for your cable investment with the Cat 6 cables, each one manufactured using high-quality copper conductors.
Rely on the RJ45 connectors to deliver optimum conductivity while eliminating signal loss due to oxidation or corrosion.
  • Reliable construction
    The cable is made with a PVC jacket that provides durability and protection against wear and tear, ensuring long-lasting use in both home and office environments.
  • Improved data transmission
    With 4 pairs of twisted wires and minimized Near-End Crosstalk, this cable supports high-speed data transfer, making it suitable for both standard and high-bandwidth applications.
  • User-friendly design
    The snagless feature allows for hassle-free handling and installation, minimizing the chances of connectors snagging during placement, making setup quick and easy.
  • Versatile connectivity
    Featuring male RJ-45 connectors on both ends, this cable easily connects to routers, switches, and other networking equipment, ensuring compatibility across various setups.
StarTech.com 5m CAT6 Ethernet Cable, 10 Gigabit Snagless RJ45 650MHz 100W PoE Patch Cord, CAT 6 10GbE UTP Network Cable w/Strain Relief, Red, Fluke Tested/Wiring is UL Certified/TIA - Category 6 - 24AWG (N6PATC5MRD) - patch cable - 5 m - red
Patch cable - CAT 6
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Snagless, minimised Near-End Crosstalk (NEXT)
Length
5 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Red
Network Cable Type
Patch cable - CAT 6
Wiring Scheme
T568B
Jacket Material
PVC
American Wire Gauge (AWG)
24
Pairs per Cable
4 pairs
Plated Connector
Gold
Length
5 m
Red
Connector
RJ-45 - male
RJ-45 - male
RoHS, ETL
9J55 StarTech.com 5m Blue Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £7.36
9J55 StarTech.com 5m Black Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £7.84
9J55 StarTech.com 5m Gray Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £9.11
9J55 StarTech.com 5m Orange Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £7.93
9J55 StarTech.com 5m Red Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £7.84
9J55 StarTech.com 5m Green Cat6 Patch Cable In Stock £6.98
9J55 StarTech.com 5m Yellow Cat6 Patch Cable In Stock £7.76
9J55 StarTech.com 5m Purple Cat6 Patch Cable In Stock £7.84
Length: 5m
Colour: Red
