StarTech.com 5m QSFP+ Breakout Cable
Quicklinx: D9V1WS00 Mfr#: QSFP4X10GAO5
Length: 5m
Colour: Black
Select:
Hurry, only 3 left in stock!
£439.71 ex VAT
£527.65 inc VAT
Connect four Cisco 10GbE SFP+ network devices with this cost-effective, active optical cable. This QSFP+ breakout cable connects a single QSFP+ port to four 10G SFP+ ports and delivers what you need most in your network connections: reliable performance. It's built to MSA specifications and fully tested to ensure seamless compatibility.
This active optical cable (AOC) is fully hot-pluggable and supports 40 Gigabit Ethernet applications connected through QSFP+ (Quad Small Form-Factor Pluggable) ports. The AOC cable is lighter and more flexible than QSFP+ direct-attach cables which makes it ideal for installation in tight spaces and over longer distances.
Designed for high-speed interconnects, this low-power, low-latency optical cable is ideal for applications such as point-to-point in-rack and across-rack network switch or server connections, for up to four 10G SFP+ devices.
StarTech.com Cisco QSFP-4X10G-AOC5M Compatible QSFP+ Breakout Cable - 5 m - breakout cable - 5 m - black
Breakout cable - SFF-8431/SFF-8432/SFF-8436
Fibre optic
Active cable
Length
5 m
Connector
QSFP+ - latched
Connector (Second End)
4 x SFP+ - latched
Network Cable Type
Fibre optic
Jacket Material
PVC
Active cable
Length
5 m
316 g
Connector
QSFP+ - latched
4 x SFP+ - latched
FCC, RoHS, MSA
70 °C
Length: 5m
Colour: Black
Price Range Ex VAT: 300 - 500
