StarTech.com 5m QSFP+ Breakout Cable
Quicklinx: D9TVWS00 Mfr#: QSFP4SFP10C5
Length: 5m
Colour: Black
£219.49 ex VAT
£263.38 inc VAT
Connect four Cisco 10GbE SFP+ network devices with this cost-effective, passive Twinax cable. This QSFP+ breakout cable connects a single QSFP+ port to four 10G SFP+ ports and delivers what you need most in your network connections: reliable performance. It's built to MSA specifications and fully tested to ensure seamless compatibility.
This passive twinaxial cable is a fully hot-pluggable, direct-attach cable, supporting 40 Gigabit Ethernet applications connected through QSFP+ (Quad Small Form Factor Pluggable) ports.
Designed for short-length, high-speed interconnects, this low-power, low-latency Twinax cable is a cost-effective alternative to fiber-optic cable assemblies. It supports short-distance applications such as point-to-point in-rack and across-rack network switch or server connections, for up to four 10G SFP+ devices.
The QSFP4SFP10C5 is a reliable replacement cable for the Cisco QSFP-4SFP10G-CU5M.
StarTech.com Cisco QSFP-4SFP10G-CU5M Compatible 5m 40G QSFP+ to 4x SFP+ Direct Attach Breakout Cable Twinax, 40GbE QSFP+ Copper DAC 40 Gbps Low Power Passive Transceiver DAC, 40GE Cable - Lifetime Warranty (QSFP4SFP10C5) - direct attach cable - 5 m - black
Direct attach cable - SFF-8431/SFF-8432/SFF-8436
Twinaxial
Shielding Material
Copper
Passive cable, Hot-pluggable
Length
5 m
Connector
QSFP+
Connector (Second End)
4 x SFP+
Network Cable Type
Twinaxial
Shielding Material
Copper
Jacket Material
PVC
American Wire Gauge (AWG)
26
Impedance
100 Ohm
Length
5 m
1.4 cm
1.2 cm
316 g
Connector
QSFP+
4 x SFP+
FCC, RoHS, WEEE, MSA, RCM
70 °C
Length: 5m
Colour: Black
