Brand
StarTech.com 5m Orange Gigabit Snagless RJ45 UTP Cat6 Patch Cable
Quicklinx: 9J54WS00 Mfr#: N6PATC5MOR
Make Power-over-Ethernet-capable Gigabit network connections. The N6PATC5MOR Cat 6 Patch Cable (5m) meets or exceeds all Category 6 cable specifications to ensure reliable Gigabit network connections, and features a durable orange PVC jacket that enables you to color code your network cable runs as needed.
To ensure long-lasting performance, this high quality Cat 6 patch cable features a snagless design that protects the RJ45 connector clips from damage and makes the cable less prone to snagging during installation. The cable also features molded PVC strain relief that prevents the RJ45 connector termination points from bending at sharp angles, reducing the risk of cable failure.
Constructed of only top quality materials, this Cat 6 Patch Cord delivers reliable performance.
Get the highest value for your cable investment with the Cat 6 cables, each one manufactured using high-quality copper conductors.
Rely on the RJ45 connectors to deliver optimum conductivity while eliminating signal loss due to oxidation or corrosion.
StarTech.com 5m CAT6 Ethernet Cable, 10 Gigabit Snagless RJ45 650MHz 100W PoE Patch Cord, CAT 6 10GbE UTP Network Cable w/Strain Relief, Orange, Fluke Tested/Wiring is UL Certified/TIA - Category 6 - 24AWG (N6PATC5MOR) - patch cable - 5 m - orange
Patch cable - CAT 6
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Snagless
Length
5 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Orange
Network Cable Type
Patch cable - CAT 6
Wiring Scheme
T568B
Jacket Material
PVC
American Wire Gauge (AWG)
24
Pairs per Cable
4 pairs
Plated Connector
Gold
Snagless
Length
5 m
Orange
Connector
RJ-45 - male
RJ-45 - male
RoHS, ETL
9J54 StarTech.com 5m Blue Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £6.09
9J54 StarTech.com 5m Black Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £6.09
9J54 StarTech.com 5m Gray Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £6.09
9J54 StarTech.com 5m Red Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £6.09
9J54 StarTech.com 5m White Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £6.09
9J54 StarTech.com 5m Green Cat6 Patch Cable In Stock £6.09
9J54 StarTech.com 5m Yellow Cat6 Patch Cable In Stock £6.09
9J54 StarTech.com 5m Purple Cat6 Patch Cable In Stock £6.09
