StarTech.com 5m OM4 Multimode Fiber Cable
Quicklinx: HHY5WS00 Mfr#: 450FBLCLC5SW
Length: 5m
Colour: Aqua
Hurry, only 3 left in stock!
£40.67 ex VAT
£48.80 inc VAT
LC/UPC to LC/UPC OM4 Multimode Switchable Fiber Optic Cable enables 40/100G network connections. The retractable strain-relief housings enable toolless in-field polarity swapping. Color-coded LC-Duplex connectors ensure error-free polarity configuration.
  • Engineered for Optimal Performance
    Precision-manufactured ceramic ferrules ensure accurate fiber alignment to prevent connectivity issues and minimize insertion loss. Designed for reliability in high-density network applications, the LC to LC UPC polished fiber ends greatly improves return loss characteristics. The Laser-Optimized Multi-Mode Fiber (LOMMF) OM4 fiber patch cable is ideal for 850nm and 1300nm Vertical-Cavity Surface-Emitting Laser (VCSEL) and LED sources.
  • Compatibility
    This multimode 50/125µm fiber optic patch cord is backward compatible with OM3 and 1/10/40G networks, ensuring a reliable connection in legacy fiber environments.
  • LSZH Cable Jacket
    Housed in a LSZH (Low-Smoke, Zero-Halogen) flame-retardant jacket, this OM4 fiber cable emits low smoke and toxic fumes when exposed to extreme heat or in the event of a fire. This enables safer cable installations in areas with poor ventilation including some industrial settings, self-contained environments such as trains and aircraft, as well as residential settings where compliance with building codes must be considered. Each OM4 fiber cable is also individually tested for insertion loss performance that meets or exceeds the TIA/EIA-568 industry standard, for guaranteed compatibility and 100% reliability.
StarTech.com 5m (15ft) LC to LC (UPC) OM4 Switchable Fiber Optic Cable 50/125µm, 100G Networks, Toolless Polarity Switching, Low Insertion Loss - LSZH Fiber Patch Cord (450FBLCLC5SW) - patch cable - 5 m - aqua
Patch cable - OM3/OM4
Duplex fibre optic
Type of Fibre Optics
Multimode
Halogen-free, up to 100 Gbps data transfer rate, Laser-optimized multimode fibre (LOMMF), bend insensitive, low insertion loss, aramid fibre reinforced, push/pull tab, wavelength of 850/1300 nm, easy polarity management
Length
5 m
Diameter
2.9 mm
Core / Cladding Diameter
50 / 125 micron
Connector
2 x LC/UPC multi-mode - male
Connector (Second End)
Aqua
Network Cable Type
Duplex fibre optic
Multimode
Jacket Material
Low Smoke Zero Halogen (LSZH)
50 / 125 micron
Length
5 m
Diameter
2.9 mm
41 g
Aqua
Connector
WEEE, EMI, TIA/EIA-568
Shipping Width
22 cm
Shipping Depth
20 cm
Shipping Height
1.6 cm
Shipping Weight
52 g
-20 °C
60 °C
Length: 5m
Colour: Aqua
