StarTech.com 5m Multimode 50/125 Duplex Fiber Patch Cable LC - ST
Quicklinx: 8M49WS00 Mfr#: 50FIBLCST5
Length: 5m
Colour: Orange
£14.51 ex VAT
£17.41 inc VAT
Connect fiber network devices for high-speed transfers with LSZH rated cable. The 50FIBLCST5 5m LSZH LC to ST Fiber Cable features 50/125 micron fiber for high-speed, high bandwidth data transmissions over Gigabit Ethernet and Fiber Channel networks, with support for duplex multimode applications.
This LC-ST patch cable is housed in a LSZH (Low-Smoke, Zero-Halogen) flame retardant jacket, to ensure minimal smoke, toxicity and corrosion when exposed to high sources of heat, in the event of a fire. Making it ideal for use in industrial settings, central offices and schools, as well as residential settings where building codes are a consideration.
Each Duplex 50/125 (OM2) Multimode Fiber Patch Cable is individually tested and certified to be within acceptable optical insertion loss limits for guaranteed compatibility and 100% reliability.
StarTech.com 5m Fiber Optic Cable - Multimode Duplex 50/125 - LSZH - LC/ST - OM2 - LC to ST Fiber Patch Cable - patch cable - 5 m - orange
Patch cable - OM2
Duplex fibre optic
Type of Fibre Optics
Multimode
Molded
Length
5 m
Core / Cladding Diameter
50 / 125 micron
Connector
2 x ST multi-mode - male
Connector (Second End)
2 x LC multi-mode - male
Orange
P/N: MCM1110MMLC
Network Cable Type
Patch cable - OM2
Duplex fibre optic
Multimode
Jacket Material
Low Smoke Zero Halogen (LSZH)
Fibre Qty
2
50 / 125 micron
Molded
Length
5 m
Orange
Connector
RoHS
P/N: MCM1110MMLC
Length: 5m
Colour: Orange
Stock Status: In stock
