StarTech.com 5m Multimode 50/125 Duplex Fiber Patch Cable LC - LC
Quicklinx: 7Y1NWS00 Mfr#: 50FIBLCLC5
Length: 5m
£18.91 ex VAT
£22.69 inc VAT
Connect fiber network devices for high-speed transfers with LSZH rated cable. The 50FIBLCLC5 5m LSZH LC to LC Fiber Cable features 50/125 micron fiber for high-speed, high bandwidth data transmissions over Gigabit Ethernet and Fiber Channel networks, with support for duplex multimode applications.
This LC-LC patch cable is housed in a LSZH (Low-Smoke, Zero-Halogen) flame retardant jacket, to ensure minimal smoke, toxicity and corrosion when exposed to high sources of heat, in the event of a fire. Making it ideal for use in industrial settings, central offices and schools, as well as residential settings where building codes are a consideration.
Each Duplex 50/125 (OM2) Multimode Fiber Patch Cable is individually tested and certified to be within acceptable optical insertion loss limits for guaranteed compatibility and 100% reliability.
StarTech.com 5m Fiber Optic Cable - Multimode Duplex 50/125 - LSZH - LC/LC - OM2 - LC to LC Fiber Patch Cable - network cable - 5 m
Network cable
Duplex fibre optic
Type of Fibre Optics
Multimode
Length
5 m
Core / Cladding Diameter
50 / 125 micron
Connector
2 x LC multi-mode - male
Connector (Second End)
P/N: 3CSFP91ST, EXSFP1GESXST, GLCLHSM10PST, GLCLHSMD10ST, GLCLHSMDST, GLCLHSMDSTTA, GLCSXMM10PST, GLCSXMMDST, GLCSXMMDSTT, GLCSXMMRGDST, J4858C10PKST, J4858CST, J4859C10PKST, J4859CST, JD118BST, MASFP1GBSXST, SFP100BFXST, SFPF1302C, SFPGESST, SFPGLCLHSMST, SFPGLCSXMMST, SFPSXMM
Network Cable Type
Network cable
Duplex fibre optic
Multimode
50 / 125 micron
Length
5 m
Connector
Length: 5m
Stock Status: In stock
