StarTech.com 5m LC to SC OS2 Fiber Cable
Quicklinx: J1KGWS00 Mfr#: SPSMLCSC-OS2-5M
21 In Stock
£15.69 ex VAT
£18.82 inc VAT
  • High Performance Connectivity
    Featuring a wavelength range of 1260-1625 nm, this fiber cable is optimized for stable and efficient data transfer in various network configurations.
  • Robust and Reliable Construction
    With ceramic ferrule technology and aramid fiber reinforcement, this cable is designed to endure physical stress and maintain connectivity over time.
  • Environmentally Friendly Design
    The low smoke zero halogen (LSZH) jacket ensures that this cable is safe for indoor use, reducing harmful emissions in case of fire.
  • Flexible Installation Capability
    The cable's bend insensitive design, with a tight bending radius of 10 mm, enables installations in various restricted spaces without signal loss.
  • Broad Compatibility
    The cable is equipped with LC/UPC and SC/UPC connectors, ensuring seamless integration into existing fiber optic networks.
StarTech.com 5m (16.4ft) LC to SC (UPC) OS2 Single Mode Fiber Cable - patch cable - 5 m - yellow
Patch cable - OS1/OS2
Simplex fibre optic
Type of Fibre Optics
Singlemode
Halogen-free, bi-directional, passive adapter, up to 100 Gbps, bend insensitive, low insertion loss, Coarse Wavelength Division Multiplexing (CWDM) support, ceramic ferrule, 0.3 dB insertion loss, aramid fibre reinforced, bending radius 10mm, wavelength of 1260-1625 nm, 55 dB return loss
Length
5 m
Diameter
2 mm
Core / Cladding Diameter
9 / 125 micron
Connector
LC/UPC single-mode - male
Connector (Second End)
SC/UPC single-mode - male
Yellow
Network Cable Type
Simplex fibre optic
Singlemode
Jacket Material
Low Smoke Zero Halogen (LSZH)
9 / 125 micron
Length
5 m
Diameter
2 mm
Yellow
Connector
EMI, ITU-T G.652.D, ITU-T G.657.A1
Shipping Width
22 cm
Shipping Depth
20 cm
Shipping Height
0.23 cm
-20 °C
60 °C
