StarTech.com 5m LC/LC OM5 Fiber Cable
Quicklinx: HHX9WS00 Mfr#: LCLCL-5M-OM5-FIBER
Length: 5m
Colour: Green
10 In Stock
£30.22 ex VAT
£36.26 inc VAT
OM5 FIBER CABLE: The OM5 LOMMF cable is optimized for 40/100 Gbps fiber optic networks. Extended 850-953 nm wavelength support enables SWDM (Short Wavelength Division Multiplexing) for greater channel isolation.
QUALITY CONSTRUCTION: LC/LC-UPC ends for better return loss than PC polishing - Color-coded connectors for polarity - Fiber core insensitive to bending, Aramid sheathing for a maggione bend radius.
RELIABLE: individually tested for guaranteed performance (testing included). LSZH sheathing emits low toxic fumes in case of combustion. Safe in poorly ventilated spaces. Attenuation value <2.4 dB/km meets/exceeds standards.
WIDE COMPATIBILITY: OM5 multimode cable supports 10/40/100G networks, compatible with OM4/OM3. High resistance to microbending facilitates bending in complex installations, ideal for fiber switches/servers, SANs and SFP+/QSFP+/QSFP28 modules.
SPECIFICATIONS: OM5 - LC/LC (UPC) - 50/125µm - 850-953nm VCSEL/1300nm LED - Modal bandwidth: 4700MHz.km (850nm), 2470MHz.km (953nm) - Insertion loss: =0.3dB - Return loss: =30dB - Cable Ø: 2.9mm - Bend radius: 3-6cm
  • High-speed connectivity
    Experience fast data transfer rates of up to 100 Gbps, ideal for high-bandwidth applications and critical tasks. This cable's technology supports a wide range of wavelengths, ensuring compatibility and performance.
  • Enhanced durability
    Constructed with a Low Smoke Zero Halogen (LSZH) jacket, this fiber optic cable minimizes the risk of smoke and fume toxicity in the event of a fire, making it a safer choice for your networking needs.
  • Optimized for laser
    Featuring Laser-optimized multimode fibers (LOMMF), this cable is designed to enhance the performance and reliability of your network by supporting a wavelength range of 840/953/1300 nm, perfect for VCSEL laser sources.
StarTech.com 5m (15ft) LC to LC (UPC) OM5 Multimode Fiber Optic Cable, 50/125µm Duplex LOMMF Zipcord, VCSEL, 40G/100G, Bend Insensitive, Low Insertion Loss, LSZH Fiber Patch Cord - patch cable - 5 m - green
Patch cable - OM5
Duplex fibre optic
Type of Fibre Optics
Multimode
Halogen-free, up to 100 Gbps data transfer rate, Laser-optimized multimode fibre (LOMMF), wavelength of 840/953/1300 nm
Length
5 m
Diameter
2.9 mm
Core / Cladding Diameter
50 / 125 micron
Connector
2 x LC/UPC multi-mode - male
Connector (Second End)
Green
Network Cable Type
Patch cable - OM5
Duplex fibre optic
Multimode
Jacket Material
50 / 125 micron
Length
5 m
Diameter
2.9 mm
Green
Connector
RoHS
Shipping Width
22 cm
Shipping Depth
20 cm
Shipping Height
1 cm
Shipping Weight
47.5 g
-20 °C
60 °C
HHX9 StarTech.com 10m LC/LC OM5 Fiber Cable In Stock £44.98
HHX9 StarTech.com 15m LC/LC OM5 Fiber Cable In Stock £56.38
HHX9 StarTech.com 1m LC/LC OM5 Fiber Cable In Stock £17.78
HHX9 StarTech.com 20m LC/LC OM5 Fiber Cable In Stock £69.18
HHX9 StarTech.com 2m LC/LC OM5 Fiber Cable In Stock £19.56
HHX9 StarTech.com 3m LC/LC OM5 Fiber Cable In Stock £24.53
HHX9 StarTech.com 5m LC/LC OM5 Fiber Cable In Stock £30.22
Length: 5m
Colour: Green
