StarTech.com 5m Grey Cat6 SFTP Cable
Quicklinx: BMQ5WS00 Mfr#: N6SPAT5MGR
Length: 5m
Colour: Grey
£12.55 ex VAT
£15.06 inc VAT
Deliver high-performance Gigabit network connections, free of noise and EMI/RFI interference. This 5-meter Cat6 cable meets or exceeds all Category 6 cable specifications to ensure reliable Gigabit network connections. And the cable is shielded to protect your network against electromagnetic interference (EMI/RFI) and system noise to provide the perfect solution for fast and safe network connections.
Constructed with 100% copper and foil shielded twisted-pair wiring, this cable was built for quality performance. The cable is designed to protect the data traveling through your network and is perfect in environments with a large amount of EMI. The results are faster speeds and improved data transmission.
The 50-micron gold connectors deliver optimum conductivity and eliminate signal loss due to oxidation or corrosion.
For easier cable runs, the snagless connectors protect the RJ45 clips during installation, making them less prone to snagging or breaking. This ensures a sturdy connection by preventing the cable from becoming loose from the plug.
Plus, the molded boots offer strain relief that stops the RJ45 connector termination points from bending at sharp angles, which reduces the risk of damage to the cable that could decrease network performance.
  • Durable construction
    The PVC jacket of the Ethernet cable provides a robust exterior, protecting the internal wires from damage and ensuring long-lasting performance.
  • Superior connectivity
    With RJ-45 male connectors on both ends, this cable supports stable and efficient data transmission, suitable for high-speed networking applications.
  • Enhanced performance
    Supporting frequencies up to 500 MHz, the cable is designed to handle high-bandwidth applications, making it ideal for gaming and streaming.
StarTech.com 5m CAT6 Ethernet Cable, 10 Gigabit Shielded Snagless RJ45 100W PoE Patch Cord, CAT 6 10GbE SFTP Network Cable w/Strain Relief, Grey, Fluke Tested/Wiring is UL Certified/TIA - Category 6 - 26AWG (N6SPAT5MGR) - patch cable - 5 m - grey
Patch cable - CAT 6
Shielded foiled twisted pair (SFTP)
Wires per Cable
8 wires
Molded, snagless
Length
5 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Grey
Network Cable Type
Patch cable - CAT 6
Jacket Material
PVC
American Wire Gauge (AWG)
26
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Molded, snagless
Length
5 m
Grey
Connector
RJ-45 - male
RJ-45 - male
RoHS, TIA/EIA-568-B - up to 500 MHz
BMQ5 StarTech.com 3m Gray Cat6 SFTP Cable In Stock £10.89
BMQ5 StarTech.com 2m Grey Cat6 SFTP Cable In Stock £8.95
Length: 5m
Colour: Grey
