StarTech.com 5m Green Cat6 Patch Cable
Quicklinx: B2W8WS00 Mfr#: N6PATC5MGN
Length: 5m
Colour: Green
More than 50 In Stock
£6.98 ex VAT
£8.37 inc VAT
Make Power-over-Ethernet-capable Gigabit network connections. The N6PATC5MGN Cat 6 patch cable (5m) meets or exceeds all Category 6 cable specifications to ensure reliable Gigabit network connections, and features a durable green PVC jacket that enables you to color code your network cable runs as needed.
To ensure long-lasting performance, this high quality Cat 6 patch cable features a snagless design that protects the RJ45 connector clips from damage and makes the cable less prone to snagging during installation. The cable also features molded PVC strain relief that prevents the RJ45 connector termination points from bending at sharp angles, reducing the risk of cable failure.
Get the highest value for your cable investment with the Cat 6 cables, each one manufactured using high-quality copper conductors.
Rely on the RJ45 connectors to deliver optimum conductivity while eliminating signal loss due to oxidation or corrosion.
  • Reliable connectivity
    This cable provides stable and efficient network connections, making it ideal for high-speed Internet access and data communication.
  • Snagless design
    The snagless feature prevents cable snags and connector damage during installation, ensuring a hassle-free setup.
  • Gold plated connectors
    The RJ-45 connectors are gold plated, enhancing connection quality and minimizing the risk of corrosion over time.
  • Compliance with standards
    Adheres to industry standards such as RoHS, ETL, and TIA/EIA-568-B, ensuring the cable meets stringent quality and safety requirements.
StarTech.com 5m CAT6 Ethernet Cable, 10 Gigabit Snagless RJ45 650MHz 100W PoE Patch Cord, CAT 6 10GbE UTP Network Cable w/Strain Relief, Green, Fluke Tested/Wiring is UL Certified/TIA - Category 6 - 24AWG (N6PATC5MGN) - patch cable - 5 m - green
Patch cable - CAT 6
Unshielded twisted pair (UTP)
Wires per Cable
4 wires
Snagless
Length
5 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Green
Network Cable Type
Patch cable - CAT 6
Jacket Material
PVC
American Wire Gauge (AWG)
24
Wires per Cable
4 wires
Pairs per Cable
8 pairs
Plated Connector
Gold
Snagless
Length
5 m
Green
Connector
RJ-45 - male
RJ-45 - male
RoHS, ETL, TIA/EIA-568-B - up to 500 MHz
B2W8 StarTech.com 5m Blue Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £7.36
B2W8 StarTech.com 5m Black Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £7.84
B2W8 StarTech.com 5m Gray Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £8.55
B2W8 StarTech.com 5m Orange Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £7.93
B2W8 StarTech.com 5m Red Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £7.84
B2W8 StarTech.com 5m Green Cat6 Patch Cable In Stock £6.98
B2W8 StarTech.com 5m Yellow Cat6 Patch Cable In Stock £7.76
B2W8 StarTech.com 5m Purple Cat6 Patch Cable In Stock £7.84
Length: 5m
Colour: Green
