Make Power-over-Ethernet-capable Gigabit network connections. The N6PATC5MGN Cat 6 patch cable (5m) meets or exceeds all Category 6 cable specifications to ensure reliable Gigabit network connections, and features a durable green PVC jacket that enables you to color code your network cable runs as needed.
To ensure long-lasting performance, this high quality Cat 6 patch cable features a snagless design that protects the RJ45 connector clips from damage and makes the cable less prone to snagging during installation. The cable also features molded PVC strain relief that prevents the RJ45 connector termination points from bending at sharp angles, reducing the risk of cable failure.
Get the highest value for your cable investment with the Cat 6 cables, each one manufactured using high-quality copper conductors.
Rely on the RJ45 connectors to deliver optimum conductivity while eliminating signal loss due to oxidation or corrosion.
Reliable connectivity
This cable provides stable and efficient network connections, making it ideal for high-speed Internet access and data communication. -
Snagless design
The snagless feature prevents cable snags and connector damage during installation, ensuring a hassle-free setup. -
Gold plated connectors
The RJ-45 connectors are gold plated, enhancing connection quality and minimizing the risk of corrosion over time. -
Compliance with standards
Adheres to industry standards such as RoHS, ETL, and TIA/EIA-568-B, ensuring the cable meets stringent quality and safety requirements.
 - StarTech.com 5m CAT6 Ethernet Cable, 10 Gigabit Snagless RJ45 650MHz 100W PoE Patch Cord, CAT 6 10GbE UTP Network Cable w/Strain Relief, Green, Fluke Tested/Wiring is UL Certified/TIA - Category 6 - 24AWG (N6PATC5MGN) - patch cable - 5 m - green
 - Patch cable - CAT 6
- Technology
- Wires per Cable
 - 4 wires
 - Snagless
- Length
 - 5 m
- Connector
 - RJ-45 - male
- Connector (Second End)
 - RJ-45 - male
 - Green
 - Limited lifetime warranty
- Network Cable Type
- Technology
- Jacket Material
 - PVC
- American Wire Gauge (AWG)
 - 24
- Wires per Cable
 - 4 wires
- Pairs per Cable
 - 8 pairs
- Plated Connector
 - Gold
 - Snagless
- Length
 - 5 m
 - Green
- Connector
 - RJ-45 - male
 - RJ-45 - male
 - RoHS, ETL, TIA/EIA-568-B - up to 500 MHz
                        StarTech.com 5m Blue Gigabit Snagless RJ45 UTP Cat6 Patch Cable | In Stock | £6.82 |
                        StarTech.com 5m Black Gigabit Snagless RJ45 UTP Cat6 Patch Cable | In Stock | £6.98 |
                        StarTech.com 5m Gray Gigabit Snagless RJ45 UTP Cat6 Patch Cable | In Stock | £8.25 |
                        StarTech.com 5m Orange Gigabit Snagless RJ45 UTP Cat6 Patch Cable | In Stock | £7.07 |
                        StarTech.com 5m Red Gigabit Snagless RJ45 UTP Cat6 Patch Cable | In Stock | £8.02 |
                        StarTech.com 5m Green Cat6 Patch Cable | In Stock | £7.15 |
                        StarTech.com 5m Purple Cat6 Patch Cable | In Stock | £7.15 |
