Create Ultra HD connections between your HDMI-enabled devices with minimal clutter; supports Ethernet Data Channel. The HDMM5MFL Flat High Speed HDMI Cable (5-meter) supports the advanced capabilities of the High Definition Multimedia Interface, including Ethernet data interconnectivity with compatible HDMI devices. The cable features a flat-shaft design that makes it the ideal solution for in-wall installations or installation under carpet or along baseboards.
This high quality HDMI cable fully supports 1080p+ resolutions at up to 120Hz refresh rate, with life-like color. To accommodate the demands of future high definition devices, such as increased resolutions and higher frame rates, this Ultra HD cable supports resolutions up to 4k x 2k.
Durable construction
The cable is made with a PVC jacket that offers durability and flexibility, suitable for various installations. -
Excellent signal quality
Gold-plated connectors enhance signal transmission, reducing potential losses for improved audio and video clarity. -
Enhanced compatibility
Equipped with 19-pin HDMI Type-A connectors, this cable works with a wide range of devices, making it a versatile option for any setup. -
Effective shielding
The aluminum mylar foil shielding helps protect against electromagnetic interference, ensuring a stable connection. -
3D transmission support
Featuring support for 3D-Transmission, this cable allows users to enjoy immersive 3D content in compatible setups.
 - StarTech.com 5m Flat High Speed HDMI Cable with Ethernet Ultra HD 4kx2k - HDMI cable with Ethernet - 5 m
- Cable
- Technology
 - Shielded
- American Wire Gauge (AWG)
 - 28
- Length
 - 5 m
 - Black
- Connector
 - HDMI - male
- Connector (Second End)
 - HDMI - male
 - 3D-Transmission
 - Limited lifetime warranty
- Cable Type
- Technology
 - Shielded
 - 28
- Jacket Material
 - PVC
- Shielding Material
 - Aluminum mylar foil with braid
- Length
 - 5 m
- Plated Connector
 - Gold
 - 3D-Transmission
 - Black
- Connector
 - 19 pin HDMI Type A - male
 - RoHS
 - Limited warranty - lifetime
