StarTech.com 5m Flat High Speed HDMI Cable with Ethernet - Ultra HD 4k x 2k HDMI Cable
Quicklinx: 8196WS00 Mfr#: HDMM5MFL
Length: 5m
15 In Stock
£14.22 ex VAT
£17.06 inc VAT
Create Ultra HD connections between your HDMI-enabled devices with minimal clutter; supports Ethernet Data Channel. The HDMM5MFL Flat High Speed HDMI Cable (5-meter) supports the advanced capabilities of the High Definition Multimedia Interface, including Ethernet data interconnectivity with compatible HDMI devices. The cable features a flat-shaft design that makes it the ideal solution for in-wall installations or installation under carpet or along baseboards.
This high quality HDMI cable fully supports 1080p+ resolutions at up to 120Hz refresh rate, with life-like color. To accommodate the demands of future high definition devices, such as increased resolutions and higher frame rates, this Ultra HD cable supports resolutions up to 4k x 2k.
  • Durable construction
    The cable is made with a PVC jacket that offers durability and flexibility, suitable for various installations.
  • Excellent signal quality
    Gold-plated connectors enhance signal transmission, reducing potential losses for improved audio and video clarity.
  • Enhanced compatibility
    Equipped with 19-pin HDMI Type-A connectors, this cable works with a wide range of devices, making it a versatile option for any setup.
  • Effective shielding
    The aluminum mylar foil shielding helps protect against electromagnetic interference, ensuring a stable connection.
  • 3D transmission support
    Featuring support for 3D-Transmission, this cable allows users to enjoy immersive 3D content in compatible setups.
StarTech.com 5m Flat High Speed HDMI Cable with Ethernet Ultra HD 4kx2k - HDMI cable with Ethernet - 5 m
Cable
Shielded
American Wire Gauge (AWG)
28
Length
5 m
Connector
HDMI - male
Connector (Second End)
HDMI - male
3D-Transmission
Cable Type
Shielded
28
Jacket Material
PVC
Shielding Material
Length
5 m
Plated Connector
Gold
3D-Transmission
Connector
19 pin HDMI Type A - male
RoHS
Limited warranty - lifetime
Length: 5m
