StarTech.com 5m DisplayPort to HDMI Cable - 4K
Quicklinx: C9J4WS00 Mfr#: DP2HDMM5MB
16 In Stock
£22.36 ex VAT
£26.83 inc VAT
Eliminate clutter by connecting your DP computer directly to an HDMI display, using this 5-meter cable. This 5-meter (16 ft.) DisplayPort to HDMI adapter cable lets you connect your DisplayPort equipped Ultrabook, laptop or desktop computer to an HDMI television, monitor or projector, with no additional adapters or cables required. The passive adapter supports video resolutions up to Ultra HD 4K, ensuring support for high-resolution applications.
This adapter cable ensures you can maintain an astonishing 4K picture quality, four times the resolution of 1080p, when converting DisplayPort to HDMI. The adapter is also backward-compatible with lower-resolution displays and video sources. With support for high-definition resolutions of 1080p and 720p, you can future-proof your existing setup for 4K video.
For the simplest and most discreet installation, this DP to HDMI adapter connects directly from your DisplayPort video source to the HDMI port on your display. It doesn't need a power source, unlike some converter dongles that require active power and separate bulky video cabling.
With a built-in DP to HDMI adapter, this 5 m cable delivers a direct connection that eliminates the need for additional adapters, ensuring a tidy, professional installation. Plus, because the cable is 5 meters (16 feet) in length, the cable is ideal when connecting your computer to a display that's much further away than a standard 6 ft. (2 m) cable.
For shorter installations, a 1 m DP to HDMI cable (DP2HDMM1MB), 2 m DP to HDMI cable (DP2HDMM2MB) and a 3 m DP to HDMI cable (DP2HDMM3MB) enable you to choose the right cable length for your custom installation needs.
  • Astonishing picture quality
  • Hassle-free setup
  • Clutter-free installation
    With a built-in DP to HDMI adapter, this 5 m cable delivers a direct connection that eliminates the need for additional adapters, ensuring a tidy, professional installation. Plus, because the cable is 5 meters (16 feet) in length, the cable is ideal when connecting your computer to a display that's much further away than a standard 6 ft. (2 m) cable. For shorter installations, we also offer a 1 m DP to HDMI cable (DP2HDMM1MB), 2 m DP to HDMI cable (DP2HDMM2MB) and a 3 m DP to HDMI cable (DP2HDMM3MB), enabling you to choose the right cable length for your custom installation needs. The DP2HDMM5MB is backed by a 3-year StarTech.com warranty and free lifetime technical support.
StarTech.com 5m (16 ft) DisplayPort to HDMI Adapter Cable - 4K DisplayPort to HDMI Converter Cable - Computer Monitor Cable (DP2HDMM5MB) - adapter cable - DisplayPort / HDMI - 5 m
Cable
Adapter cable - DisplayPort / HDMI
Length
5 m
Connector
DisplayPort - male
Connector (Second End)
HDMI - male
DisplayPort 1.2
4K support
3-year warranty
Cable Type
Adapter cable 4K support
Interface Supported
DisplayPort / HDMI
DisplayPort 1.2
Length
5 m
HDCP compliant, DPCP compliant
Connector
20 pin DisplayPort - male
19 pin HDMI Type A - male
Plug and Play, FCC, RoHS
Limited warranty - 3 years
C9J4 StarTech.com DisplayPort to HDMI Video Adapter Converter In Stock £12.93
C9J4 StarTech.com DisplayPort to HDMI Video Adapter Converter - M/F In Stock £11.76
C9J4 StarTech.com DisplayPort to DVI Video Adapter Converter In Stock £10.99
C9J4 StarTech.com DisplayPort to HDMI Video Adapter Converter In Stock £16.23
C9J4 StarTech.com DisplayPort to HDMI 4K Audio / Video Converter – DP 1.2 to HDMI Active Adapter In Stock £20.93
C9J4 StarTech.com 3ft DP to HDMI cable - 4K In Stock £14.83
C9J4 StarTech.com 6 ft DP to HDMI cable - 4K In Stock £16.30
C9J4 StarTech.com 5m DisplayPort to HDMI Cable - 4K In Stock £22.36
C9J4 StarTech.com 3m DisplayPort to HDMI Cable - 4K In Stock £21.81
