StarTech.com 5m Coax High Resolution Monitor VGA Video Cable with Audio HD15 M/M
Quicklinx: 84MYWS00 Mfr#: MXTHQMM5MA
Length: 5m
13 in stock
£16.51 ex VAT
£19.81 inc VAT
Make VGA video and audio connections using a single, high quality cable. The MXTHQMM5MA 5-meter High Resolution VGA Cable with Audio is a high quality SVGA cable designed to provide the highest video quality possible through VGA - a single cable solution for connecting both video between a VGA video card and monitor, and audio connections between a sound card and external audio device.
StarTech.com's high resolution VGA cable with audio features high quality male-to-male coaxial VGA cable, and is designed to eliminate picture "ghosting" and fuzzy images that are inherent to non-coaxial cables, while providing superior EMI interference protection by using ferrite cores near the connector ends.
StarTech.com 5m Coax High Resolution Monitor VGA Video Cable with Audio - VGA cable - 5 m
VGA cable
Double shielded twisted pair triple coaxial
Molded, thumbscrews, strain relief, ferrite core
Length
5 m
Connectors
HD-15 (VGA) - male , Stereo mini jack - male
Connectors (Second End)
UL 2919, RoHS, NEC-CMG
VGA cable
Shielding Material
American Wire Gauge (AWG)
28
Plated Connector
Nickel
Length
5 m
Connectors
15 pin HD D-Sub (HD-15) - male , Mini-phone stereo 3.5 mm - male
84MY StarTech.com Slimline Adapter HDDB15 F/F In Stock £4.40
84MY StarTech.com Right Angle VGA to VGA Cable Adapter Type 1 - M/F In Stock £6.09
84MY StarTech.com Right Angle VGA to VGA Cable Adapter Type 2 - M/F In Stock £6.09
Length: 5m
Price Range Ex VAT: 0 - 50
