StarTech.com 5m Cisco Compatible SFP+ 10-Gigabit Ethernet (10GbE) Passive Twinax Direct Attach Cable
Quicklinx: 8JFQWS00 Mfr#: SFPCMM5M
Length: 5m
Colour: Black
Hurry, only 3 left in stock!
£60.13 ex VAT
£72.15 inc VAT
Connect 10GbE SFP+ network devices with this high-quality replacement SFP-H10GB-CU5M cable. The SFPCMM5M Cisco Compatible 5m SFP+ cable is a fully hot pluggable, direct attach cable, supporting 10 Gigabit Ethernet and Fiber Channel applications connected through (Small Form Factor Pluggable) SFP+ ports.
Designed for short length, high speed interconnects, this low power, low latency Twinax cable is a cost-effective alternative to fiber optic cable assemblies and is intended for short distance applications such as point-to-point in-rack and across rack network switch/server connections.
This 10GBASE-CU SFP+ Cable is compliant with MSA (Multi-Source Agreement) standards, making it a reliable replacement SFP-H10GB-CU5M cable.
  • Reliable connection
    This direct-attach cable features latching connectors that provide a secure connection, preventing accidental disconnections during operation.
  • Efficient performance
    With twinaxial technology, this cable ensures high-speed data transfer with minimal signal loss, ideal for networking between devices.
  • Robust construction
    The PVC jacket material offers protection against wear and tear, making it suitable for various environmental conditions.
  • Operating temperature range
    Designed to function effectively in temperatures from 0°C to 70°C, this cable adapts well to different operating environments.
  • Environmentally compliant
    This cable adheres to RoHS standards, making it a responsible choice for environmentally-conscious users.
StarTech.com Cisco SFP-H10GB-CU5M Compatible 5m 10G SFP+ to SFP+ Direct Attach Cable Twinax, 10GbE SFP+ Copper DAC 10Gbps Low Power Passive Mini GBIC/Transceiver Module DAC, 10G SFP+ Cable - Lifetime Warranty (SFPCMM5M) - direct attach cable - 5 m
Direct attach cable
Twinaxial
Latching connectors
Length
5 m
Connector
SFP+
Connector (Second End)
SFP+
P/N: PEX10000SFPI, PEX10GSFP4I, PEX20000SFPI
Network Cable Type
Direct attach cable
Twinaxial
Jacket Material
PVC
American Wire Gauge (AWG)
30
Impedance
100 Ohm
Latching connectors
Length
5 m
Connector
SFP+
SFP+
RoHS
70 °C
8JFQ StarTech.com 1m Cisco Compatible SFP+ 10-Gigabit Ethernet (10GbE) Passive Twinax Direct Attach Cable In Stock £36.36
8JFQ StarTech.com 2m Cisco Compatible SFP+ 10-Gigabit Ethernet (10GbE) Passive Twinax Direct Attach Cable In Stock £40.56
8JFQ StarTech.com 3m Cisco Compatible SFP+ 10-Gigabit Ethernet (10GbE) Passive Twinax Direct Attach Cable In Stock £46.24
8JFQ StarTech.com 5m Cisco Compatible SFP+ 10-Gigabit Ethernet (10GbE) Passive Twinax Direct Attach Cable In Stock £60.13
Length: 5m
Colour: Black
