The shielded Cat6a cables ensure fast and dependable 10 Gigabit network connections by protecting against electromagnetic interference (EMI/RFI) and noise. The result is a fast and safe network.
Each cable is tested for up to 500 MHz frequency and is more than suitable for 10GBase-T Ethernet networks.
Plus, the RJ45 connectors are both snagless and molded to prevent damage to the connector clips and the cable. This helps to avoid accidental disconnections and decreases in network performance.
Reliable performance
The patch cable is engineered to achieve data transmission speeds of up to 10 Gbps, making it suitable for high-bandwidth applications. -
Safe materials
Constructed with a Low Smoke Zero Halogen (LSZH) jacket, this cable is designed to minimize harmful smoke in case of fire, ensuring safety in various environments. -
Robust design
Features such as strain relief and a molded, snagless construction protect against damage and ensure a stable connection during use. -
Compliant standards
This cable complies with multiple standards, including IEEE 802.3bt and ANSI/TIA-568.2-D, ensuring compatibility with a range of networking equipment. -
Excellent shielding
Utilizes foil shielding to reduce electromagnetic interference, providing a clean signal and reducing Return Loss for reliable performance.
- StarTech.com 5m CAT6a Ethernet Cable - White - Low Smoke Zero Halogen (LSZH) - 10GbE 500MHz 100W PoE++ Snagless RJ-45 w/Strain Reliefs S/FTP Network Patch Cord - patch cable - 5 m - white
- Patch cable - CAT 6a - IEEE 802.3bt
- Technology
- S/FTP
- Shielding Material
- Foil
- Wires per Cable
- 8 wires
- Halogen-free, molded, snagless, stranded, strain relief, minimised Near-End Crosstalk (NEXT), test fluke pass, copper conductor, EMI/RFI protection, 100 Watt maximum input power, reduced Return Loss (RL), damage protection, up to 10 Gbps
- Length
- 5 m
- Connector
- RJ-45 - male
- Connector (Second End)
- RJ-45 - male
- White
- Limited lifetime warranty
- Network Cable Type
- Technology
- S/FTP
- Foil
- Jacket Material
- American Wire Gauge (AWG)
- 27
- Wires per Cable
- 8 wires
- Pairs per Cable
- 4 pairs
- Plated Connector
- Gold
- Length
- 5 m
- 174.6 g
- White
- Connector
- RJ-45 - male
- RJ-45 - male
- RoHS, ETL, WEEE, ANSI/TIA-568.2-D, PoE++ - up to 500 MHz
- Shipping Width
- 20.5 cm
- Shipping Depth
- 18 cm
- Shipping Height
- 3 cm
- Shipping Weight
- 183.3 g
StarTech.com 5m CAT6a Ethernet Cable LSZH - White
