StarTech.com 5m CAT6a Ethernet Cable LSZH - White
Quicklinx: H15QWS00 Mfr#: NLWH-5M-CAT6A-PATCH
Length: 5m
Colour: White
£20.25 ex VAT
£24.30 inc VAT
The shielded Cat6a cables ensure fast and dependable 10 Gigabit network connections by protecting against electromagnetic interference (EMI/RFI) and noise. The result is a fast and safe network.
Each cable is tested for up to 500 MHz frequency and is more than suitable for 10GBase-T Ethernet networks.
Plus, the RJ45 connectors are both snagless and molded to prevent damage to the connector clips and the cable. This helps to avoid accidental disconnections and decreases in network performance.
  • Reliable performance
    The patch cable is engineered to achieve data transmission speeds of up to 10 Gbps, making it suitable for high-bandwidth applications.
  • Safe materials
    Constructed with a Low Smoke Zero Halogen (LSZH) jacket, this cable is designed to minimize harmful smoke in case of fire, ensuring safety in various environments.
  • Robust design
    Features such as strain relief and a molded, snagless construction protect against damage and ensure a stable connection during use.
  • Compliant standards
    This cable complies with multiple standards, including IEEE 802.3bt and ANSI/TIA-568.2-D, ensuring compatibility with a range of networking equipment.
  • Excellent shielding
    Utilizes foil shielding to reduce electromagnetic interference, providing a clean signal and reducing Return Loss for reliable performance.
StarTech.com 5m CAT6a Ethernet Cable - White - Low Smoke Zero Halogen (LSZH) - 10GbE 500MHz 100W PoE++ Snagless RJ-45 w/Strain Reliefs S/FTP Network Patch Cord - patch cable - 5 m - white
Patch cable - CAT 6a - IEEE 802.3bt
S/FTP
Shielding Material
Foil
Wires per Cable
8 wires
Halogen-free, molded, snagless, stranded, strain relief, minimised Near-End Crosstalk (NEXT), test fluke pass, copper conductor, EMI/RFI protection, 100 Watt maximum input power, reduced Return Loss (RL), damage protection, up to 10 Gbps
Length
5 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
White
Network Cable Type
S/FTP
Shielding Material
Foil
Jacket Material
American Wire Gauge (AWG)
27
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Length
5 m
174.6 g
White
Connector
RJ-45 - male
RJ-45 - male
RoHS, ETL, WEEE, ANSI/TIA-568.2-D, PoE++ - up to 500 MHz
Shipping Width
20.5 cm
Shipping Depth
18 cm
Shipping Height
3 cm
Shipping Weight
183.3 g
Length: 5m
Colour: White
