StarTech.com 5m CAT6a Ethernet Cable LSZH - Blue
Quicklinx: H15CWS00 Mfr#: NLBL-5M-CAT6A-PATCH
Hurry, only 1 left in stock!
£18.87 ex VAT
£22.64 inc VAT
CAT6A ETHERNET CABLE: Ethernet cable for error-free 1/2.5/5/10Gbps multi-gigabit/multi-speed connections - Low proximity crosstalk (NEXT)/return loss (RL) - Meets ANSI/TIA-568.2-D standards - Tested by Fluke and Verified by ETL.
SHIELDED CAT6A CABLE: Enhanced signal and EMI/RFI protection - Individual twisted pairs wrapped in aluminum foil - Outer cover with braided shield - Shielded RJ45 connectors with gold-plated pins.
100W ETHERNET POWER SUPPLY: 100% stranded copper wire provides stable PoE power, unlike copper-clad aluminum versions - Supports PoE devices up to 100W PoE++ - IEEE 802.3bt compliant.
DURABLE LSZH SHEATH: PVC-free, low-smoke, halogen-free (LSZH) cable sheath produces less dense, less corrosive smoke than PVC - Braided FABRICATION resists damage caused by bending.
SPECS: Category 6A network cable - 5m - Blue - 10Gbps - 500 MHz - 4 pairs S/FTP - RJ-45 snagless with strain relief - EVA, Al(OH)3 - LSZH - 27 AWG - 100% copper - ETL verified - ANSI/TIA-568.2-D - Supports Cat6 and earlier standards.
  • High-speed performance
    This patch cable is capable of delivering data transfer speeds of up to 10 Gbps, making it suitable for high-demand networking tasks.
  • Effective shielding
    The foil shielding of this cable minimizes Near-End Crosstalk (NEXT), ensuring reliable data transmission and reduced interference.
  • Safe and reliable construction
    The Low Smoke Zero Halogen (LSZH) jacket provides enhanced safety in case of fire, emitting less smoke and harmful fumes.
  • Power over Ethernet capability
    This cable can support up to 100 W of power input, making it suitable for devices that require Power over Ethernet (PoE++).
  • Durable design features
    The cable includes strain relief and snagless connectors to protect against cable damage and ensure longevity.
StarTech.com 5m CAT6a Ethernet Cable - Blue - Low Smoke Zero Halogen (LSZH) - 10GbE 500MHz 100W PoE++ Snagless RJ-45 w/Strain Reliefs S/FTP Network Patch Cord - patch cable - 5 m - blue
Patch cable - CAT 6a - IEEE 802.3bt
S/FTP
Shielding Material
Foil
Wires per Cable
8 wires
Snagless, stranded, molded, halogen-free, minimised Near-End Crosstalk (NEXT), strain relief, test fluke pass, EMI/RFI protection, up to 10 Gbps, copper conductor, 100 Watt maximum input power, damage protection, reduced Return Loss (RL)
Length
5 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Blue
Network Cable Type
S/FTP
Shielding Material
Foil
Jacket Material
American Wire Gauge (AWG)
27
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Length
5 m
174.6 g
Blue
Connector
RJ-45 - male
RJ-45 - male
RoHS, WEEE, PoE++, ANSI/TIA-568.2-D, ETL - up to 500 MHz
Shipping Width
20.5 cm
Shipping Depth
18 cm
Shipping Height
3 cm
Shipping Weight
183.3 g
