Ethernet cable CAT6a 5m - Low Smoke Zero Halogen (LSZH), 10 Gigabit 500MHz 100W PoE RJ45 S/FTP Turquoise Snagless network cable (NLAQ-5M-CAT6A-PATCH).
Reliable connectivity
This cable supports advanced networking standards with compatibility for IEEE 802.3bt, allowing it to deliver power over Ethernet while maintaining high data transfer rates. -
Superior shielding technology
With S/FTP technology, this cable minimizes Near-End Crosstalk (NEXT), ensuring high data integrity and optimal performance, especially in environments with multiple cables. -
Durable construction
Built with strain relief features and damage protection, this cable is designed to withstand wear and tear, making it suitable for frequent use in various settings. -
Versatile compatibility
This CAT6a Ethernet cable is compliant with multiple standards including RoHS, ETL, and PoE++, ensuring it meets safety and performance expectations. -
Efficient performance
A tested frequency of up to 500 MHz allows this cable to support high-speed networking applications, providing efficient data transfer and enhancing network capabilities.
 - StarTech.com 5m CAT6a Ethernet Cable - Aqua - Low Smoke Zero Halogen (LSZH) - 10GbE 500MHz 100W PoE++ Snagless RJ-45 w/Strain Reliefs S/FTP Network Patch Cord - patch cable - 5 m - aqua
 - Patch cable - CAT 6a - IEEE 802.3bt
- Technology
 - S/FTP
- Shielding Material
 - Foil
- Wires per Cable
 - 8 wires
 - Snagless, stranded, molded, halogen-free, minimised Near-End Crosstalk (NEXT), strain relief, test fluke pass, EMI/RFI protection, up to 10 Gbps, copper conductor, 100 Watt maximum input power, damage protection, reduced Return Loss (RL)
- Length
 - 5 m
- Connector
 - RJ-45 - male
- Connector (Second End)
 - RJ-45 - male
 - Aqua
 - Limited lifetime warranty
- Network Cable Type
- Technology
 - S/FTP
 - Foil
- Jacket Material
- American Wire Gauge (AWG)
 - 27
- Wires per Cable
 - 8 wires
- Pairs per Cable
 - 4 pairs
- Plated Connector
 - Gold
- Length
 - 5 m
 - 174.6 g
 - Aqua
- Connector
 - RJ-45 - male
 - RJ-45 - male
 - RoHS, WEEE, PoE++, ANSI/TIA-568.2-D, ETL - up to 500 MHz
- Shipping Width
 - 20.5 cm
- Shipping Depth
 - 18 cm
- Shipping Height
 - 3 cm
- Shipping Weight
 - 183.3 g
