StarTech.com 5m CAT6a Ethernet Cable - Blue - CAT6a STP Cable - Snagless
Quicklinx: FSHPWS00 Mfr#: 6ASPAT5MBL
£20.27 ex VAT
£24.32 inc VAT
This CAT6a Ethernet cable meets all Category 6a cable specifications. It ensures reliable 10Gb connections between your network devices.
Tested for up to 500MHz frequency, each CAT6a cable is more than suitable for 10GBase-T Ethernet networks.
Built for quality performance, the cable features 100% copper and foil-shielded, twisted-pair wiring. The cable is designed to keep the data signals traveling through your network free from noise and interference. It's perfect in environments that are prone to large amounts of electromagnetic interference (EMI/RFI).
This CAT6a patch cable is built using 100% copper wire and is tested to comply with ANSI/TIA 568 C.2 Category 6a requirements. StarTech.com doesn't use copper-clad aluminum (CCA) wire which is subject to problems like weak power delivery, heat buildup, equipment damage and possibly fire.
The 50-micron gold connectors deliver optimum conductivity and eliminate signal loss due to oxidation or corrosion.
For trouble-free cable runs, this durable cable features snagless connectors that protect the RJ45 clips during installation, making them less likely to snag or break.
The CAT6a Ethernet cable also features molded boots which offer strain relief by stopping the RJ45 connectors from bending at sharp angles. This reduces the risk of cable damage, which could decrease network connectivity and performance.
  • Durable construction
    The cable is made from high-quality PVC jacket material, ensuring longevity and resistance to wear in various environments.
  • High performance
    This Ethernet cable supports a tested frequency of up to 500 MHz, making it suitable for high-bandwidth applications.
  • Effective shielding
    Aluminum-polyester foil shielding helps minimize interference from external RFI and EMI sources, maintaining signal integrity.
  • Secure connections
    The gold-plated connectors deliver excellent connectivity, reducing the risk of corrosion and ensuring reliable data transmission.
  • Environmentally friendly
    Compliant with RoHS and REACH standards, this Ethernet cable meets important environmental regulations.
StarTech.com 5m CAT6A Ethernet Cable, 10 Gigabit Shielded Snagless RJ45 100W PoE Patch Cord, CAT 6A 10GbE STP Network Cable w/Strain Relief, Blue, Fluke Tested/UL Certified Wiring/TIA - Category 6A - 26AWG (6ASPAT5MBL) - patch cable - 5 m - blue
Patch cable - CAT 6a
Shielded twisted pair (STP)
Shielding Material
Aluminium-polyester foil
Wires per Cable
8 wires
Molded, snagless, strain relief, PoE ready, RFI/EMI shielding
Length
5 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Blue
Network Cable Type
Shielding Material
Jacket Material
PVC
American Wire Gauge (AWG)
25
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Length
5 m
Blue
Connector
RJ-45 - male
RJ-45 - male
RoHS, REACH - up to 500 MHz
FSHP StarTech.com 5m CAT6a Ethernet Cable - Aqua - CAT6a STP Cable - Snagless In Stock £9.53
FSHP StarTech.com 5m CAT6a Ethernet Cable - Black - CAT6a STP Cable - Snagless In Stock £20.60
