Deliver high-performance Gigabit network connections, free of noise and EMI/RFI interference. This 5-meter Cat6 cable meets or exceeds all Category 6 cable specifications to ensure reliable Gigabit network connections. The cable is shielded to protect your network against electromagnetic interference (EMI/RFI) and system noise, providing the perfect solution for fast and safe network connections.
Constructed with 100% copper and foil-shielded twisted-pair wiring, this cable delivers high-quality performance. It's designed to keep the data signals traveling through your network free from interference, so it's perfect in environments that are prone to large amounts of EMI.
The 50-micron gold connectors deliver optimum conductivity and eliminate signal loss due to oxidation or corrosion.
For easier cable runs, the snagless connectors protect the RJ45 clips during installation, making them less likely to snag or break. This ensures a sturdy connection by preventing the cable from becoming loose from the port.
Plus, the molded boots offer strain relief that stops the RJ45 connector termination points from bending at sharp angles, which reduces the risk of damage to the cable that could decrease network performance.
Durable design
The molded construction of the cable ensures resilience against wear and tear during installation and daily usage. -
Strain relief feature
This feature prevents stress on the cable, reducing the risk of damage at the connector points. -
Easy installation
The snagless connector design allows for smooth insertion and removal, making network setup more efficient. -
Advanced connectivity
With RJ-45 male connectors on both ends, this cable provides flexibility and convenience for various networking needs.
- StarTech.com 5m CAT6 Ethernet Cable, 10 Gigabit Shielded Snagless RJ45 100W PoE Patch Cord, CAT 6 10GbE SFTP Network Cable w/Strain Relief, Black, Fluke Tested/Wiring is UL Certified/TIA - Category 6 - 26AWG (N6SPAT5MBK) - patch cable - 5 m - black
- Patch cable - CAT 6
- Technology
- Shielded foiled twisted pair (SFTP)
- Molded, snagless, strain relief
- Length
- 5 m
- Connector
- RJ-45 - male
- Connector (Second End)
- RJ-45 - male
- Black
- Limited lifetime warranty
- Network Cable Type
- Technology
- Plated Connector
- Gold
- Length
- 5 m
- Black
- Connector
- RJ-45 - male
- RJ-45 - male
StarTech.com 1m Black Cat6 / Cat 6 Shielded (SFTP) Patch Cable | In Stock | £7.58 |
StarTech.com 0.5m Black Cat6 / Cat 6 Shielded (SFTP) Patch Cable | In Stock | £6.45 |
StarTech.com 3m Black Cat6 / Cat 6 Shielded (SFTP) Patch Cable | In Stock | £9.64 |
StarTech.com 2m Black Cat6 / Cat 6 Shielded (SFTP) Patch Cable | In Stock | £8.38 |
StarTech.com 5m Black Cat6 SFTP Cable | In Stock | £14.22 |
