Make Fast Ethernet connections with support for PoE. This 5-meter Cat5e cable meets or exceeds all Category 5e cable specifications to ensure reliable Ethernet network connections. Plus, the cable features a durable black PVC jacket that enables you to color code your network cable runs as needed.
For easier cable runs, the snagless connectors protect the cable's RJ45 clips during installation, making them less likely to snag or break. This ensures a sturdy connection by preventing the cable from becoming loose from the port.
The cable features molded boots that offer connector strain relief, by stopping the RJ45 connector termination points from bending at sharp angles, and reducing the risk of damage to the cable, which could decrease network performance.
Snagless RJ45 clips help protect your network connections
For easier cable runs, the snagless connectors protect the cable's RJ45 clips during installation, making them less likely to snag or break. This ensures a sturdy connection by preventing the cable from becoming loose from the port. The cable features moulded boots that offer connector strain relief, by stopping the RJ45 connector termination points from bending at sharp angles, and reducing the risk of damage to the cable, which could decrease network performance. -
100% copper for outstanding value
Get the highest value for your cable investment with our Cat 5e cables, each one manufactured using high-quality copper conductors. -
24-gauge wire for high-performance network connection
Ensure high-performance capability for your demanding Ethernet applications, such as Power-over-Ethernet, using cables that include 24 AWG copper. -
50-micron gold connectors provide peak conductivity
Rely on our RJ45 connectors to deliver optimum conductivity while eliminating signal loss due to oxidation or corrosion. The 45PAT5MBK is backed by StarTech.com's lifetime warranty for guaranteed reliability.
- StarTech.com 5m Black Cat5e / Cat 5 Snagless Patch Cable 5 m - patch cable - 5 m - black
- Patch cable - CAT 5e
- Technology
- Snagless, minimised Near-End Crosstalk (NEXT)
- Length
- 5 m
- Connector
- RJ-45 - male
- Connector (Second End)
- RJ-45 - male
- Black
- Limited lifetime warranty
- Network Cable Type
- Technology
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 24
- Pairs per Cable
- 4 pairs
- Length
- 5 m
- 10 g
- Black
- Connector
- RJ-45 - male
- RJ-45 - male
- RoHS - up to 350 MHz
StarTech.com Grey Cat5e Snagless Patch Cable 5m | In Stock | £6.65 |
StarTech.com 5m Blue Cat 5e Patch Cable | In Stock | £6.65 |
StarTech.com 5m Black Cat 5e Patch Cable | In Stock | £6.65 |
StarTech.com 5m Orange Cat5e Patch Cable | In Stock | £5.96 |
StarTech.com 5m White Cat5e Patch Cable | In Stock | £6.65 |
StarTech.com 5m Red Cat5e Patch Cable | In Stock | £6.65 |
StarTech.com 5m Green Cat5e Patch Cable | In Stock | £6.65 |
