StarTech.com 5m Aqua OM4 LC Fiber Cable
Quicklinx: CZCSWS00 Mfr#: 450FBLCLC5
Length: 5m
Colour: Aqua
£20.77 ex VAT
£24.92 inc VAT
Connect 40GBase-SR4, 100GBase-SR10, SFP+ and QSFP+ transceivers in 40 and 100 Gigabit networks. This fiber optic cable lets you connect 40GBase-SR4, 100GBase-SR10, SFP+ and QSFP+ transceivers in 40 and 100 Gigabit networks. The OM4 cable supports Vertical Cavity Surface Emitting Laser (VCSEL) and LED light sources and is backward compatible with your existing 50/125 equipment.
This Aqua OM4 duplex multimode fiber cable is housed in a LSZH (Low-Smoke, Zero-Halogen) flame retardant jacket, to ensure minimal smoke, toxicity and corrosion when exposed to high sources of heat, in the event of a fire. It's ideal for use in industrial settings, central offices and schools, as well as residential settings where building codes are a consideration.
Each OM4 fiber cable is individually tested and certified to be within acceptable optical insertion loss limits for guaranteed compatibility and 100% reliability.
  • Reliable performance
    This patch cable supports a tested frequency of up to 3500 MHz, ensuring efficient data transmission with minimal loss.
  • Durable construction
    The Low Smoke Zero Halogen (LSZH) jacket material enhances safety by reducing smoke and toxic emissions in case of fire.
  • Versatile application
    Suitable for various networking needs, this cable features LC to LC connectors for compatibility with a wide range of devices.
  • High-quality technology
    Equipped with Laser-optimized multimode fiber (LOMMF), this cable provides efficient performance for multimode applications.
  • Standard compliance
    This patch cable adheres to OM4 standards and is RoHS compliant, making it a responsible choice for network installations.
StarTech.com Aqua OM4 Duplex Multimode Fiber - 16 ft / 5m - 100 Gb - 50/125 - OM4 Fiber - LC to LC Fiber Patch Cable (450FBLCLC5) - network cable - 5 m - aqua
Network cable - OM4
Duplex fibre optic
Type of Fibre Optics
Multimode
Laser-optimized multimode fibre (LOMMF), VCSEL array technology
Length
5 m
Core / Cladding Diameter
50 / 125 micron
Connector
2 x LC multi-mode - male
Connector (Second End)
Aqua
Network Cable Type
Network cable - OM4
Duplex fibre optic
Multimode
Jacket Material
50 / 125 micron
Length
5 m
Aqua
Connector
RoHS - up to 3500 MHz
CZCS StarTech.com 1m Aqua OM4 LC Fiber Cable In Stock £17.33
CZCS StarTech.com 2m Aqua OM4 LC Fiber Cable In Stock £18.93
CZCS StarTech.com 5m Aqua OM4 LC Fiber Cable In Stock £20.77
CZCS StarTech.com 3m Aqua OM4 LC Fiber Cable In Stock £21.64
Length: 5m
Colour: Aqua
