Connect 40GBase-SR4, 100GBase-SR10, SFP+ and QSFP+ transceivers in 40 and 100 Gigabit networks. This fiber optic cable lets you connect 40GBase-SR4, 100GBase-SR10, SFP+ and QSFP+ transceivers in 40 and 100 Gigabit networks. The OM4 cable supports Vertical Cavity Surface Emitting Laser (VCSEL) and LED light sources and is backward compatible with your existing 50/125 equipment.
This Aqua OM4 duplex multimode fiber cable is housed in a LSZH (Low-Smoke, Zero-Halogen) flame retardant jacket, to ensure minimal smoke, toxicity and corrosion when exposed to high sources of heat, in the event of a fire. It's ideal for use in industrial settings, central offices and schools, as well as residential settings where building codes are a consideration.
Each OM4 fiber cable is individually tested and certified to be within acceptable optical insertion loss limits for guaranteed compatibility and 100% reliability.
Reliable performance
This patch cable supports a tested frequency of up to 3500 MHz, ensuring efficient data transmission with minimal loss. -
Durable construction
The Low Smoke Zero Halogen (LSZH) jacket material enhances safety by reducing smoke and toxic emissions in case of fire. -
Versatile application
Suitable for various networking needs, this cable features LC to LC connectors for compatibility with a wide range of devices. -
High-quality technology
Equipped with Laser-optimized multimode fiber (LOMMF), this cable provides efficient performance for multimode applications. -
Standard compliance
This patch cable adheres to OM4 standards and is RoHS compliant, making it a responsible choice for network installations.
- StarTech.com Aqua OM4 Duplex Multimode Fiber - 16 ft / 5m - 100 Gb - 50/125 - OM4 Fiber - LC to LC Fiber Patch Cable (450FBLCLC5) - network cable - 5 m - aqua
- Network cable - OM4
- Technology
- Duplex fibre optic
- Type of Fibre Optics
- Multimode
- Laser-optimized multimode fibre (LOMMF), VCSEL array technology
- Length
- 5 m
- Core / Cladding Diameter
- 50 / 125 micron
- Connector
- 2 x LC multi-mode - male
- Connector (Second End)
- Aqua
- Limited lifetime warranty
- Network Cable Type
- Technology
- Multimode
- Jacket Material
- Low Smoke Zero Halogen (LSZH)
- 50 / 125 micron
- Length
- 5 m
- Aqua
- Connector
- RoHS - up to 3500 MHz
StarTech.com 1m Aqua OM4 LC Fiber Cable | In Stock | £17.33 |
StarTech.com 2m Aqua OM4 LC Fiber Cable | In Stock | £19.15 |
StarTech.com 5m Aqua OM4 LC Fiber Cable | In Stock | £20.77 |
StarTech.com 3m Aqua OM4 LC Fiber Cable | In Stock | £21.64 |
