Connect your Cisco 40GbE QSFP+ network devices with this cost-effective, passive Twinax copper cable. This 40G QSFP+ cable delivers what you need most in your network connections: reliable performance. It's built to MSA specifications and fully tested to ensure seamless compatibility.
This passive twinaxial cable is a fully hot-pluggable, direct-attach cable, supporting 40 Gigabit Ethernet applications connected through QSFP+ (Quad Small-Form Factor Pluggable) ports.
Designed for short-length, high-speed interconnects, this low-power, low-latency Twinax cable is a cost-effective alternative to fiber-optic cable assemblies, supporting short-distance applications such as point-to-point in-rack and across-rack network switch or server connections.
The QSFPH40GCU5M is a reliable replacement cable for the Cisco QSFP-H40G-CU5M.
- StarTech.com Cisco QSFP-H40G-CU5M Compatible 5m 40G QSFP+ to QSFP+ DAC Twinax, 40GbE QSFP+ Copper DAC 40 Gbps Low Power Passive Transceiver Module DAC, Cisco Firepower C9200, QSFP+ Cable - Lifetime Warranty (QSFPH40GCU5M) - direct attach cable - 5 m - black
- Direct attach cable - SFF-8436
- Technology
- Twinaxial
- Shielding Material
- Copper
- Passive cable, Hot-pluggable
- Length
- 5 m
- Connector
- QSFP+
- Connector (Second End)
- QSFP+
- Black
- OEM Manufacturer Equivalent Part Number
- Cisco QSFP-H40G-CU5M
- 2-year warranty
- Network Cable Type
- Technology
- Twinaxial
- Copper
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 28
- Impedance
- 100 Ohm
- Length
- 5 m
- 1.8 cm
- 1.3 cm
- 316 g
- Black
- Connector
- QSFP+
- QSFP+
- FCC, RoHS, WEEE, RCM
- 2-year warranty
- 0 °C
- 70 °C
StarTech.com 0.5m 1.6ft 40G QSFP+ DAC Cable | In Stock | £58.18 |
StarTech.com 3m 9.8ft 40G QSFP+ DAC Cable | In Stock | £155.36 |
StarTech.com 5m 16.4ft 40G QSFP+ DAC Cable | In Stock | £244.60 |
