Connect your HP 10GbE SFP+ network devices with this cost-effective, passive Twinax copper cable. This 10G SFP+ cable delivers what you need most in your network connections: reliable performance. It's built to MSA specifications and fully tested to ensure seamless compatibility.
This passive twinaxial cable is a fully hot-pluggable, direct-attach cable, supporting 10 Gigabit Ethernet applications connected through SFP+ (Small Form-Factor Pluggable) ports.
Designed for short-length, high-speed interconnects, this low-power, low-latency Twinax cable is a cost-effective alternative to fiber-optic cable assemblies, supporting short-distance applications such as point-to-point in-rack and across-rack network switch or server connections.
- StarTech.com HPE JG081C Compatible 5m 10G SFP+ to SFP+ Direct Attach Cable Twinax, 10GbE SFP+ Copper DAC 10Gbps Low Power Passive Mini GBIC/Transceiver Module DAC, Firepower, 5500, SFP+ - Lifetime Warranty (JG081CST) - 10GBase direct attach cable - 5 m - black
- 10GBase direct attach cable - SFF-8431/SFF-8432
- Technology
- Twinaxial
- Passive cable
- Length
- 5 m
- Connector
- SFP+ - latched
- Connector (Second End)
- SFP+ - latched
- Black
- OEM Manufacturer Equivalent Part Number
- HP JG081C
- 2-year warranty
- Network Cable Type
- Technology
- Twinaxial
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 24
- Impedance
- 100 Ohm
- Passive cable
- Length
- 5 m
- 316 g
- Black
- Connector
- SFP+ - latched
- SFP+ - latched
- HP JG081C
- FCC, RoHS, MSA
- 2-year warranty
- 0 °C
- 70 °C
StarTech.com 1m 3.3ft 10G SFP+ DAC Cable | In Stock | £39.06 |
StarTech.com 3m 9.8ft 10G SFP+ DAC Cable | In Stock | £47.41 |
StarTech.com 7m 23ft 10G SFP+ DAC Cable | In Stock | £65.65 |
StarTech.com 3m 9.8ft 10G SFP+ DAC Cable | In Stock | £38.60 |
StarTech.com 5m 16.4ft 10G SFP+ DAC Cable | In Stock | £43.64 |
