StarTech.com 5m (15 ft) Active High Speed HDMI Cable - Ultra HD 4k x 2k HDMI Cable HDMI to HDMI M/M
Quicklinx: 95F1WS00 Mfr#: HDMM5MA
Create Ultra HD connections between your High Speed HDMI-equipped devices, up to 5m away with no signal loss. The HDMM5MA 15 ft Active High Speed HDMI Cable features a built-in active signal booster for a connection distance of up to 15 feet (5m) between your HDMI-enabled devices, with no signal loss.
This durable, lightweight cable features thinner HDMI wire construction - approximately half the thickness of a regular 5m cable, which allows for a more flexible installation with minimal clutter. Plus, the cable features built-in amplifier circuitry which actively boosts the HDMI signal with no external power required.
This high quality HDMI cable fully supports 1080p+ resolutions at up to 120Hz refresh rate, with life-like color. To accommodate the demands of future high definition devices, such as increased resolutions and higher frame rates, this Ultra HD cable supports resolutions up to 4k x 2k.
This cable features unidirectional architecture which requires that the cable is installed in the correct direction. Please refer to the "TV" label on the HDMI connector which plugs into your display, in order to ensure that the device and the HDMI source are connected properly.
StarTech.com 5m (15 ft) Active High Speed HDMI Cable - Ultra HD 4k x 2k HDMI Cable - HDMI to HDMI M/M - 1080p - Audio Video Gold-Plated (HDMM5MA) - HDMI cable - 5 m
Cable
HDMI cable
Double shielded
American Wire Gauge (AWG)
36
Length
5 m
Connector
HDMI - male
Connector (Second End)
HDMI - male
Active cable (signal regeneration)
Cable Type
HDMI cable
Double shielded
36
Jacket Material
PVC
Shielding Material
Length
5 m
Plated Connector
Gold
Connector
19 pin HDMI Type A - male
FCC, RoHS
