Connect your USB On-The-Go capable tablet computer or Smartphone to USB 2.0 devices (thumb drives, USB mouse or keyboard, etc.). The UUSBOTGW White Micro USB On-The-Go (OTG) Adapter Cable lets you convert the Micro USB port on your smartphone or tablet into a USB host port that you can use to connect a USB peripheral device such as a thumb drive, mouse or keyboard.
The adapter cable features one Micro USB (B-type) male connector and one full-size USB (A-type) port, and is compatible with OTG-capable devices.
To ensure dependable, long-lasting connections, the 5-inch Micro USB OTG adapter is durably constructed.
This adapter will only work with devices that support USB OTG. Please consult your documentation and/or your service provider to ensure that your device does support USB OTG functionality.
- StarTech.com 5in White Micro USB to USB OTG Host Adapter M/F - Micro USB Male to USB A Female On-The-Go Host Cable Adapter - White (UUSBOTGW) - USB adapter - USB to Micro-USB Type B - 12.7 cm
- USB adapter
- Technology
- Shielded
- Length
- 12.7 cm
- Connector
- 4 pin USB Type A - female
- Connector (Second End)
- 5 pin Micro-USB Type B - male
- USB 2.0 On-The-Go
- White
- Limited lifetime warranty
- USB adapter
- Technology
- Shielded
- American Wire Gauge (AWG)
- 28
- Plated Connector
- Nickel
- Length
- 12.7 cm
- White
- Connector
- USB 2.0 On-The-Go, RoHS
StarTech.com 5in Micro USB to USB OTG Host Adapter M/F | In Stock | £5.59 |
StarTech.com 5in Right Angle Micro USB to USB OTG Host Adapter M/F | In Stock | £5.06 |
