StarTech.com 5in Right Angle Micro USB to USB OTG Host Adapter M/F
Quicklinx: 9KZJWS00 Mfr#: UUSBOTGRA
32 In Stock
£5.06 ex VAT
£6.07 inc VAT
Connect your USB On-The-Go capable tablet computer or Smartphone to USB 2.0 devices (thumb drives, USB mouse or keyboard, etc.). The UUSBOTGRA Right Angle Micro USB On-The-Go Adapter Cable converts your Micro USB OTG capable Tablet or Smartphone into a USB On-The-Go host, and enables you to connect a USB peripheral device such as a flash drive, or a USB mouse or keyboard, etc. - making it perfect for hectic schedules and people on the move who need to work while traveling.
The right angle Micro USB connector allows you to position the cable and the USB device in such a way that you can still access your mobile device comfortably with reduced strain on the connection.
This OTG adapter cable is designed and constructed for maximum durability, to ensure dependable, long-lasting connections.
This adapter will only work with devices that support USB OTG. Please consult your documentation and/or your service provider to ensure that your device does support USB OTG functionality.
StarTech.com 5in Right Angle Micro USB to USB OTG Host Adapter M/F - Angled Micro USB Male to USB A Female On-The-Go Host Cable Adapter (UUSBOTGRA) - USB adapter - USB to Micro-USB Type B - 12.7 cm
USB adapter
Shielded
Right-angled connector
Length
12.7 cm
Connector
4 pin USB Type A - female
Connector (Second End)
5 pin Micro-USB Type B - male
USB 2.0 On-The-Go
USB adapter
Shielded
American Wire Gauge (AWG)
28
Plated Connector
Nickel
Length
12.7 cm
Connector
USB 2.0 On-The-Go, RoHS
9KZJ StarTech.com 5in Micro USB to USB OTG Host Adapter M/F In Stock £5.59
9KZJ StarTech.com 5in Right Angle Micro USB to USB OTG Host Adapter M/F In Stock £5.06
9KZJ StarTech.com 20" Micro-USB Extension Cable In Stock £5.30
9KZJ StarTech.com 8" Micro USB OTG Cable In Stock £5.76
