StarTech.com 5in Micro USB to USB OTG Host Adapter M/F
Quicklinx: 8GTYWS00 Mfr#: UUSBOTG
26 In Stock
£5.32 ex VAT
£6.38 inc VAT
Connect your USB On-the-Go capable tablet computer or Smartphone to USB 2.0 devices (thumb drives, USB mouse or keyboard, etc.). The UUSBOTG Micro USB On-The-Go (OTG) Adapter Cable features a Micro USB male (B-type) connector and a USB female (A-type) connector, delivering a simple way to convert your Micro USB OTG capable tablet computer or Smartphone into a USB On-the-go host, and enables you to connect a USB peripheral device such as a thumb drive, or USB mouse or keyboard, etc.
This USB to Micro USB Host OTG cable is designed and constructed for maximum durability, to ensure dependable, long-lasting connections.
This adapter will only work with devices that support USB OTG. Please consult your documentation and/or your service provider to ensure that your device does support USB OTG functionality.
StarTech.com 5in Micro USB to USB OTG Host Adapter - Micro USB Male to USB A Female On-The-GO Host Cable Adapter (UUSBOTG) - USB adapter - USB to Micro-USB Type B - 12.7 cm
USB adapter
Shielded
Length
12.7 cm
Connector
4 pin USB Type A - female
Connector (Second End)
5 pin Micro-USB Type B - male
USB 2.0 On-The-Go
P/N: ST4300U3C1, ST4300U3C1B
USB adapter
Shielded
American Wire Gauge (AWG)
28
Plated Connector
Nickel
Length
12.7 cm
Connector
USB 2.0 On-The-Go, RoHS
8GTY StarTech.com 5ft Desktop USB Extension Cable - A Male to A Female In Stock £5.29
8GTY StarTech.com 1 ft Panel Mount USB Cable A to A - F/M In Stock £4.93
8GTY StarTech.com 10ft USB 2.0 Extension Cable A to A - M/F In Stock £4.95
8GTY StarTech.com 3 ft Black USB 2.0 Extension Cable A to A - M/F In Stock £4.17
8GTY StarTech.com 6 ft Black USB 2.0 Extension Cable A to A - M/F In Stock £4.26
8GTY StarTech.com 6in USB 2.0 Extension Adapter Cable A to A - M/F In Stock £4.61
8GTY StarTech.com 1 Port USB over Cat5 / Cat6 Ethernet Extender - up to 131ft (40m) In Stock £103.22
8GTY StarTech.com 20m USB 2.0 Active Extension Cable - M/F In Stock £87.44
8GTY StarTech.com 5in Micro USB to USB OTG Host Adapter M/F In Stock £5.32
8GTY StarTech.com 15m USB 2.0 Active Extension Cable - M/F In Stock £69.91
8GTY StarTech.com 3m White USB 2.0 Extension Cable A to A - M/F In Stock £6.30
8GTY StarTech.com 1m White USB 2.0 Extension Cable A to A - M/F In Stock £5.25
8GTY StarTech.com 3 ft Panel Mount USB Cable A to A - F/M In Stock £5.45
8GTY StarTech.com 10m USB 2.0 Active Extension Cable - M/F In Stock £60.44
8GTY StarTech.com 25m USB 2.0 Active Extension Cable - M/F In Stock £104.13
8GTY StarTech.com 5m USB 2.0 Active Extension Cable - M/F In Stock £43.27
8GTY StarTech.com 5in Right Angle Micro USB to USB OTG Host Adapter M/F In Stock £5.49
8GTY StarTech.com 2 ft Panel Mount USB Cable A to A - F/M In Stock £7.54
8GTY StarTech.com 20" Micro-USB Extension Cable In Stock £5.03
8GTY StarTech.com 8" Micro to Mini USB OTG Cable In Stock £5.62
8GTY StarTech.com 8" Micro USB OTG Cable In Stock £5.59
