Connect your USB On-the-Go capable tablet computer or Smartphone to USB 2.0 devices (thumb drives, USB mouse or keyboard, etc.). The UUSBOTG Micro USB On-The-Go (OTG) Adapter Cable features a Micro USB male (B-type) connector and a USB female (A-type) connector, delivering a simple way to convert your Micro USB OTG capable tablet computer or Smartphone into a USB On-the-go host, and enables you to connect a USB peripheral device such as a thumb drive, or USB mouse or keyboard, etc.
This USB to Micro USB Host OTG cable is designed and constructed for maximum durability, to ensure dependable, long-lasting connections.
This adapter will only work with devices that support USB OTG. Please consult your documentation and/or your service provider to ensure that your device does support USB OTG functionality.
Versatile Connection Options
This adapter features a 4-pin USB Type-A female connector, making it compatible with various USB peripherals, enhancing flexibility for users. -
Enhanced Durability
Constructed with shielded technology and nickel-plated connectors, this adapter provides resistance against wear and corrosion, ensuring long-lasting use.
- StarTech.com 5in Micro USB to USB OTG Host Adapter - Micro USB Male to USB A Female On-The-GO Host Cable Adapter (UUSBOTG) - USB adapter - USB to Micro-USB Type B - 12.7 cm
- USB adapter
- Technology
- Shielded
- Length
- 12.7 cm
- Connector
- 4 pin USB Type A - female
- Connector (Second End)
- 5 pin Micro-USB Type B - male
- USB 2.0 On-The-Go
- Black
- Limited lifetime warranty
- Designed For
- P/N: ST4300U3C1, ST4300U3C1B
- USB adapter
- Technology
- Shielded
- American Wire Gauge (AWG)
- 28
- Plated Connector
- Nickel
- Length
- 12.7 cm
- Black
- Connector
- USB 2.0 On-The-Go, RoHS
- Designed For
StarTech.com 5ft Desktop USB Extension Cable - A Male to A Female | In Stock | £5.65 |
StarTech.com 1 ft Panel Mount USB Cable A to A - F/M | In Stock | £5.29 |
StarTech.com 10ft USB 2.0 Extension Cable A to A - M/F | In Stock | £5.00 |
StarTech.com 3 ft Black USB 2.0 Extension Cable A to A - M/F | In Stock | £4.06 |
StarTech.com 6 ft Black USB 2.0 Extension Cable A to A - M/F | In Stock | £4.19 |
StarTech.com 6in USB 2.0 Extension Adapter Cable A to A - M/F | In Stock | £4.92 |
StarTech.com 1 Port USB over Cat5 / Cat6 Ethernet Extender - up to 131ft (40m) | In Stock | £105.43 |
StarTech.com 20m USB 2.0 Active Extension Cable - M/F | In Stock | £76.40 |
StarTech.com 5in Micro USB to USB OTG Host Adapter M/F | In Stock | £5.59 |
StarTech.com 15m USB 2.0 Active Extension Cable - M/F | In Stock | £61.53 |
StarTech.com 3m White USB 2.0 Extension Cable A to A - M/F | In Stock | £6.37 |
StarTech.com 1m White USB 2.0 Extension Cable A to A - M/F | In Stock | £5.51 |
StarTech.com 3 ft Panel Mount USB Cable A to A - F/M | In Stock | £5.72 |
StarTech.com 10m USB 2.0 Active Extension Cable - M/F | In Stock | £53.10 |
StarTech.com 25m USB 2.0 Active Extension Cable - M/F | In Stock | £95.30 |
StarTech.com 5m USB 2.0 Active Extension Cable - M/F | In Stock | £37.96 |
StarTech.com 5in Right Angle Micro USB to USB OTG Host Adapter M/F | In Stock | £5.06 |
StarTech.com 2 ft Panel Mount USB Cable A to A - F/M | In Stock | £5.50 |
StarTech.com 20" Micro-USB Extension Cable | In Stock | £5.30 |
StarTech.com 8" Micro USB OTG Cable | In Stock | £5.76 |
