StarTech.com 5in High Speed HDMI Adapter Cable - HDMI to HDMI Mini- F/M
Quicklinx: 81T4WS00 Mfr#: HDACFM5IN
Connect your portable HDMI Mini-enabled devices to your HDMI TV or display. The HDACFM5IN 5-inch HDMI to HDMI Mini Cable adapter enables you to use a standard HDMI male-to-male cable to connect your portable HDMI-enabled devices (e.g. digital camera) to most video displays. With a Standard HDMI female connector (type A) on one end and an HDMI Mini (type C) male connector on the other, you can easily make this conversion and connect to computer monitors, HDTV or HDMI-capable projectors virtually everywhere you go. The HDMI/HDMI Mini cable features high quality, gold-tipped connectors that ensure peak connectivity.
  • Reliable Connectivity
    This adapter provides a stable connection between mini HDMI and standard HDMI ports, ensuring seamless communication between devices.
  • High-Quality Materials
    Constructed with aluminum mylar foil and a robust PVC jacket, this adapter resists wear and maintains performance over time.
  • Easy to Use
    Simply plug the mini HDMI male connector into your device and the HDMI female connector to your display for quick setup.
  • Compatible Design
    Works with a variety of devices, including cameras, smartphones, tablets, and TVs, making it a versatile addition to any tech collection.
  • Portable Size
    The compact 5 in length allows for easy transport and storage, perfect for use at home or on-the-go.
StarTech.com 5in Mini HDMI to HDMI Adapter, 4K High Speed HDMI Adapter, 4K 30Hz Ultra HD High Speed HDMI Adapter, HDMI 1.4, Gold Plated Connectors, UHD Mini HDMI Adapter 4K, Black - Mini HDMI to HDMI Converter - HDMI adapter - 1.3 cm
Cable
HDMI adapter
Shielded
American Wire Gauge (AWG)
30
Length
1.3 cm
Connector
HDMI - female
Connector (Second End)
19 pin mini HDMI Type C - male
P/N: HDMM30CM
Cable Type
HDMI adapter
Shielded
30
Jacket Material
PVC
Shielding Material
Length
1.3 cm
Plated Connector
Gold
Connector
19 pin HDMI Type A - female
Limited warranty - lifetime
P/N: HDMM30CM
81T4 StarTech.com HDMI to HDMI Mini Adapter - F/M In Stock £7.85
