Connect your HDMI Micro Device or Smartphone to your HDMI-enabled TV or Monitor. The HDADFM5IN 5-inch HDMI to HDMI Micro Cable adapter enables you to use a standard HDMI male-to-male cable to connect your portable devices (BlackBerry PlayBook, Smartphones, etc.) to most video displays.
With a Standard HDMI female connector (type A) on one end and an HDMI Micro (type D) male connector on the other, you can easily make this conversion and connect to computer monitors, HDTV or HDMI projectors virtually everywhere you go.
The HDMI/HDMI Micro cable features high quality, gold-tipped connectors that ensure peak connectivity.
- StarTech.com 5in High Speed HDMI Adapter Cable - HDMI to HDMI Micro - F/M - 5 inch Micro HDMI Adapter - HDMI Female to Micro HDMI Male (HDADFM5IN) - HDMI adapter - 1.2 cm
- Cable
- HDMI adapter
- Technology
- Shielded
- American Wire Gauge (AWG)
- 34
- Length
- 1.2 cm
- Black
- Connector
- HDMI - female
- Connector (Second End)
- 19 pin micro HDMI Type D - male
- Limited lifetime warranty
- Designed For
- P/N: HDMM30CM
- Cable Type
- HDMI adapter
- Technology
- Shielded
- 34
- Jacket Material
- PVC
- Shielding Material
- Aluminum mylar foil with braid
- Length
- 1.2 cm
- Plated Connector
- Gold
- Black
- Connector
- 19 pin HDMI Type A - female
- RoHS
- Limited warranty - lifetime
- Designed For
- P/N: HDMM30CM
