StarTech.com 5in High Speed HDMI Adapter Cable - HDMI to HDMI Micro – F/M
Quicklinx: 7RWMWS00 Mfr#: HDADFM5IN
Length: 1.2cm
More than 50 In Stock
£14.69 ex VAT
£17.62 inc VAT
Connect your HDMI Micro Device or Smartphone to your HDMI-enabled TV or Monitor. The HDADFM5IN 5-inch HDMI to HDMI Micro Cable adapter enables you to use a standard HDMI male-to-male cable to connect your portable devices (BlackBerry PlayBook, Smartphones, etc.) to most video displays.
With a Standard HDMI female connector (type A) on one end and an HDMI Micro (type D) male connector on the other, you can easily make this conversion and connect to computer monitors, HDTV or HDMI projectors virtually everywhere you go.
The HDMI/HDMI Micro cable features high quality, gold-tipped connectors that ensure peak connectivity.
  • Secure connection
    The cable features 19-pin HDMI Type-A on one end and a 19-pin micro HDMI Type D on the other, facilitating a link between various devices.
  • High-quality materials
    Constructed with aluminum mylar foil and a robust PVC jacket, this adapter cable is designed for durability while protecting against potential damage.
  • Efficient design
    With a length of just 5 inches, this cable allows for easy positioning and connection in limited spaces, enhancing organizational ease.
StarTech.com 5in High Speed HDMI Adapter Cable - HDMI to HDMI Micro - F/M - 5 inch Micro HDMI Adapter - HDMI Female to Micro HDMI Male (HDADFM5IN) - HDMI adapter - 1.2 cm
Cable
HDMI adapter
Shielded
American Wire Gauge (AWG)
34
Length
1.2 cm
Connector
HDMI - female
Connector (Second End)
19 pin micro HDMI Type D - male
P/N: HDMM30CM
Cable Type
HDMI adapter
Shielded
34
Jacket Material
PVC
Shielding Material
Length
1.2 cm
Plated Connector
Gold
Connector
19 pin HDMI Type A - female
RoHS
Limited warranty - lifetime
P/N: HDMM30CM
7RWM StarTech.com 5in High Speed HDMI Adapter Cable - HDMI to HDMI Micro – F/M In Stock £14.69
Length: 1.2cm
