Extend a USB port from the back of your computer to your desktop. The USBEXTAA5DSK desktop USB extension cable connects to an available USB female port on a Mac or PC computer, allowing you to relocate the USB (female) port up to 5 ft away from the computer case. By extending the USB port away from the computer case, you can situate a USB port in a more practical spot, such as on top of the computer case or on a desktop.
USB thumb drives or other external USB storage, the desktop USB extension cable is a perfect solution for accessing digital cameras, MP3 players.
Convenient length
At 5 ft in length, this cable provides ample reach to connect devices across your workspace, eliminating limitations from short cables. -
Versatile connectivity
The male to female design allows for versatile connections to various USB devices, facilitating easy Plug-and-Play functionality. -
Reliable data transfer
Complying with the USB 2.0 standard, this extension cable offers stable performance for data transmission, ensuring efficient operation of connected devices. -
Environmentally compliant
This cable is RoHS compliant, reflecting a commitment to reducing hazardous substances in electrical and electronic products.
- StarTech.com 5ft Desktop USB Extension Cable - A Male to A Female - 5 ft USB A to A Extension Cable - 5ft USB 2.0 Extension cord (USBEXTAA5DSK) - USB extension cable - USB to USB - 1.5 m
- Length
- 1.5 m
- Connector
- 4 pin USB Type A - male
- Connector (Second End)
- 4 pin USB Type A - female
- Black
- Limited lifetime warranty
- Designed For
- P/N: MSDREADU2OTG, USB56KEM3, USB56KEMH2, UUSBOTG
- Length
- 1.5 m
- Black
- Connector
- RoHS
- Designed For
StarTech.com 10ft USB 2.0 Extension Cable A to A - M/F | In Stock | £5.05 |
StarTech.com 3 ft Black USB 2.0 Extension Cable A to A - M/F | In Stock | £4.06 |
StarTech.com 6 ft Black USB 2.0 Extension Cable A to A - M/F | In Stock | £4.31 |
StarTech.com 5 ft Desktop SuperSpeed USB 3.0 Extension Cable - A to A M/F | In Stock | £11.51 |
StarTech.com 1m (3ft) White Apple 8-pin Lightning Connector to USB Cable for iPhone / iPod / iPad | In Stock | £13.89 |
