StarTech.com 56K USB Dial-up and Fax Modem - V.92 - External
Quicklinx: DZ6YWS00 Mfr#: USB56KEMH2
Type: Fax / modem
Enclosure: External
Interface: USB
Compatibility: Mac, PC
33 In Stock
£32.27 ex VAT
£38.72 inc VAT
Add dial-up internet access and external fax modem support to your laptop or desktop computer through USB. This hardware-based 56k USB fax modem lets you access the internet through a dial-up service, when broadband connections are not available. The compact 56k modem is powered through USB, making it a perfect accessory to have on hand when you're traveling with your laptop or need to have a backup connection to the internet for your desktop.
You can use this versatile USB modem as a backup internet connection, for traveling to remote locations, or in rural areas where broadband connections are not available. It supports transfer rates up to 56Kbps (data) and 14.4Kbps (fax) and is compatible with the latest transmission standards (V.92, V.90, and so on).
The controller-based modem uses on-chip processing to deliver dial-up access without taxing your computer's performance, saving your system's resources and minimizing the load on the CPU.
The USB modem also enables your laptop or desktop computer to function like a fax machine, capable of sending and receiving faxes. It supports the latest fax transmission modes, providing fax transfer rates at 14.4Kbps.
With a compact and lightweight design, the USB modem is portable, tucking easily into your laptop bag or travel case. It's powered through the USB host connection, making it fast and easy to connect without requiring an external power adapter.
  • Reliable and versatile internet connectivity
    You can use this versatile USB modem as a backup internet connection, for traveling to remote locations, or in rural areas where broadband connections are not available. It supports transfer rates up to 56Kbps (data) and 14.4Kbps (fax) and is compatible with the latest transmission standards (V.92, V.90, and so on). The controller-based modem uses on-chip processing to deliver dial-up access without taxing your computer's performance, saving your system's resources and minimizing the load on the CPU.
  • Send and receive faxes from your computer
  • Easy portability
    With a compact and lightweight design, the USB modem is portable, tucking easily into your laptop bag or travel case. It's powered through the USB host connection, making it fast and easy to connect without requiring an external power adapter. The USB56KEMH2 is backed by a StarTech.com 2-year warranty and free lifetime technical support.
StarTech.com USB 2.0 Fax Modem, 56K External Hardware Dial Up V.92 Modem/Dongle/Adapter, Computer/Laptop Fax Modem, USB to Telephone Jack, USB Data Modem, Network Fax/CMR/POS - 56K V.92 Modem Dongle - fax / modem
Fax / modem - USB
External
Max Transfer Rate
56 Kbps
Protocols & Specifications
Bell 103, ITU V.21, Bell 212A, ITU V.22, ITU V.22bis, ITU V.29, ITU V.32, ITU V.34, ITU V.90, ITU V.17, ITU V.23, ITU V.27ter, k56Flex, ITU V.92
Max Fax Transfer Rate
14.4 Kbps
Data Compression Protocol
ITU V.44
Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012 R2, Microsoft Windows 7 / 8 / 8.1 / 10, Microsoft Windows Server 2016, Apple MacOS X 10.9 - 10.10, Microsoft Windows Server 2019, Linux 3.16 - 4.4 LTS versions only
Fax / modem
External
Modem
Bus
USB
Wired
Max Transfer Rate
56 Kbps
56K Technology
K56Flex, V.90, V.92
ITU V.44
14.4 Kbps
1 x phone line - RJ-11 , 1 x USB - Type A
1 x RJ-11 phone cable
FCC, RoHS
Software Included
Drivers & Utilities
DZ6Y StarTech.com 5ft Desktop USB Extension Cable - A Male to A Female In Stock £5.65
DZ6Y StarTech.com 6in USB 2.0 Extension Adapter Cable A to A - M/F In Stock £4.92
Type: Fax / modem
Enclosure: External
Interface: USB
Compatibility: Mac
Compatibility: PC
