StarTech.com 55 ft Coax High Resolution Monitor VGA Cable - HD15 M/M
Quicklinx: 7P04WS00 Mfr#: MXT101MMHQ55
Connect your VGA monitor with the highest quality connection available. This 55-foot High Resolution VGA Monitor Cable is designed to provide the highest video quality possible through VGA. Ideally suited for high resolution VGA applications, this high quality male-to-male coaxial VGA cable eliminates the picture "ghosting" and fuzzy images that are inherent to non-coaxial cables, while providing superior EMI interference protection by using ferrite cores near the connector ends.
StarTech.com 55 ft Coax High Resolution Monitor VGA Cable - HD15 M/M - 55ft HD15 to HD15 Cable - 55ft VGA Monitor Cable (MXT101MMHQ55) - VGA cable - 16.8 m
VGA cable
Triple shielded twisted pair coaxial
Molded, ferrite bead
Length
16.8 m
Connector
HD-15 (VGA) - male
Connector (Second End)
HD-15 (VGA) - male
RoHS, NEC-CMG
P/N: CDP2VGA, CDP2VGAFC
VGA cable
Shielding Material
American Wire Gauge (AWG)
28
Plated Connector
Nickel
Length
16.8 m
Connector
RoHS, NEC-CMG
7P04 StarTech.com Slimline Adapter HDDB15 F/F In Stock £5.33
