55 Bits, 50x H4x28mm, 5x H4x45mm - Hard Case - Magnetic Work Pad - Magnetizer/Demagnitizer - Bit Extender
This cord-less screwdriver is the ideal tool to dismantle and reassemble electronic devices during repairs. The battery powered driver set includes a precision electric screwdriver (2 x AAA batteries included), 55 micro bits, a magnetizer/demagnetizer and a magnetic work pad, housed in a durable hard case. A complete range of bits ensures compatibility with most major brands of smartphones, tablets and laptops including but not limited to Apple iPhones, iPads, Macbooks, Samsung Galaxy, HP and Acer Chromebooks, Lenovo ThinkPads.
Precision Electric Driver with LED Work Light and Forward/Reverse Modes
The premium electric driver included with this kit has several features designed for hassle-free repairs.
A built-in LED work light illuminates the area that the driver is operating in, ensuring you can clearly see shadowless details, regardless of the lighting in your repair area.
Battery operated forward and reverse modes with 0.25 to 0.35 N.m of torque, ensures you can effortlessly install and remove screws without the wrist strain that comes with manual drivers.
The included magnetizer/demagnetizer gives you the option to magnetize the driver to ensure screws are easy to install/remove without losing them. Plus, the head can be demagnetized for IT repairs on devices that may be sensitive to magnets.
Quick changing batteries ensure uninterrupted operation.
55 Specially Selected Micro Bits
This kit features 55x4mm bits specially selected for extensive compatibility with major brands of smartphones, tablets and laptop computers. Bits Included:
Philips (crosshead) H4x28: PH0000, PH000, PH00, PH0, PH1, PH2
Philips (crosshead) H4x45: PH0, PH2
Slot (flathead) H4x28: SL1.0, SL1.5, SL 2.0, SL2.5, SL3.0, SL3.5
Slot (flathead) H4x45: SL2.5
Torx H4x28: T2, T3, T4, T5
Torx Security H4x28: T6, T7, T8, T9, T10, T15, T20
Hexagonal H4x28: H0.7, H0.9, H1.3, H1.5, H2.0, H2.5, H3.0, H3.5, H4.0
Hexagonal H4x45: H2.0, H2.5
Pentalobe H4x28: P2(0.8), P5(1.2), P6(1.5)
Spanner H4x28: U2.0, U2.6, U3.0
Tri Wing H4x28: Y0.6, Y1.0, Y2.0, Y2.5, Y3.0
Triangle H4x28: 2.0, 2.3, 2.5, 3.0
Robertson H4x28: (square) S0, S1, S2
Durable Case and Magnetic Work Pad
Included with the electric driver is a durable hard plastic case, and a convenient magnetic work pad. The carrying case features peg holes for each included bit as well as a sleek compartment for the driver, while the magnetic work pad ensures your screws and bits will stay where you place them, until you're ready use them.
CTK55PCEDRIVE is backed by a StarTech.com 2-year warranty with free 24/5 multi-lingual North American based technical support. StarTech.com has been the IT professionals' choice for over 30 years.
Precision battery-powered driver
This compact electric precision screwdriver is the perfect tool to dismantle/assemble electronics devices; the cordless aluminum driver is battery powered; LED light and buttons for forward and reverse modes -
Full tool-kit
Set includes driver, 55x precision bits, magnetic work pad, bit extender, magnetizer/demagnetizer and hard case. -
Works with most major electronic devices
The bits included have been specially selected for compatibility with major brands of smartphones, tablets and laptop computers incl but not limited to iPhone, iPad, Samsung Galaxy, HP, Acer, Chromebook ThinkPad and Macbook. -
Hassle-free operation
Portable mini power operated driver helps to prevent screw damage; Works with all 4mm bits; quick change batteries ensures uninterrupted operation, ideal for IT/repair shops.
- StarTech.com 55-Bit Electric Precision Screwdriver Set - Portable Cordless Battery Powered Bit Driver Kit for Electronics, Laptop, Computers, Tablet & Phone Repairs - Magnetic Work Pad - electric precision screwdriver - cordless - 2 batteries
- Product Type
- Electric precision screwdriver - cordless
- Speed
- 110 rpm
- Chuck Size
- 4 mm
- Max Torque (hard)
- 0.35 N·m
- Battery Qty
- 2
- Product Type
- Speed
- 110 rpm
- Chuck Size
- 4 mm
- Max Torque (hard)
- 0.35 N·m
- LED light, forward/reverse rotation
- Included Qty
- 2
Carrying Case
- Case
- Included Accessories
- 55 screwdriver bits, magnetic work pad, bit extender, magnetiser/demagnetiser
- Warranty
- 2 years
StarTech.com 20-Bit Electric Precision Screwdriver Set | In Stock | £41.98 |
StarTech.com 23x47in Anti Static Mat | In Stock | £42.11 |
StarTech.com Temperature/Humidity Meter | In Stock | £23.56 |
StarTech.com Handheld Sound Level Meter | In Stock | £22.91 |
