Build or upgrade a computer system with an energy efficient and reliable 530 Watt ATX power supply. The ATX2PW530WH 530 Watt 80 Plus Power Supply offers an energy efficient replacement or upgrade for powering your desktop PC. Operating at a minimum of 80% efficiency between 20% and 100% load, 80 Plus power supplies deliver a significant improvement over standard-efficiency power supplies that helps reduce energy consumption and cost of operation.
This versatile power supply is equipped to support AMD or Intel CPU-based servers and workstations with a combined 20/24-pin motherboard connection, and an 8-pin EPS connector.
- StarTech.com 530 Watt ATX12V 2.3 80 Plus Computer Power Supply w/ Active PFC - power supply - 530 Watt
- Power supply - active Power Factor Correction (PFC) - internal
- Specification Compliance
- ATX12V 2.3/ EPS12V 2.92
- 80 PLUS Certification
- 80 PLUS
- Input Voltage
- AC 115/230 V
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 530 Watt
- Output Current
- +12V1 - 41 A , +12V2 - 41 A , +12V3 - 41 A , +12V4 - 41 A , +3.3V - 20 A , +5V - 20 A , -12V - 0.5 A , +5VSB - 2.5 A , -5V - 20 A
- Output connectors
- 1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 1 x 8 pin PCI Express power , 4 x 15 pin Serial ATA power , 3 x 4 PIN internal power , 1 x power 4 pin ATX12V connector , 1 x 6 pin internal power
- Cooling System
- 120 mm fan
- Black
- 15 cm x 14 cm x 8.6 cm
- 2-year warranty
- PSU Form Factor
- ATX
- Black
- Input Voltage
- AC 115/230 V
- Input Voltage Range
- AC 110 - 240 V
- Frequency Required
- 50 - 60 Hz
- Power Output Connectors Details
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 530 Watt
- Output Current
- Efficiency
- 80%
- 80 PLUS
- Cooling System
- 120 mm fan
- Over current protection, over voltage protection, overpower protection, short-circuit protection, non-modular
- UL, RoHS
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 15 cm
- 14 cm
- 8.6 cm
