OS2 LC to SC Single Mode Duplex Fiber Optic Patch cable facilitates connectivity across 10G networks. It supports Coarse Wavelength Division Multiplexing (CWDM) across an extended wavelength range of 1260-1625nm, improving channel isolation for optimal signal strength over long distances.
Compatibility
This 9/125µm Single Mode fiber cable supports 1260-1625nm laser-optimized sources and is ideal for critical connections between servers, switches, and data center equipment. It is backward compatible with OS1 networks, ensuring a reliable connection in legacy fiber environments. -
Engineered for Optimal Performance
Precision-manufactured ceramic ferrules ensure correct fiber alignment to preserve insertion loss below 0.3dB. Ultra Physical Contact (UPC)-polished LC to SC fiber ends greatly improves return loss characteristics over older PC polishing techniques. The Bend Insensitive fiber core is surrounded by a layer of low refractive index material. This material reduces the amount of light that can escape the fiber cable by reflecting the light back into the fiber. The OS2 fiber patch cord is engineered for low attenuation and performance that exceeds ITU-T G652.D/G657.A1 and IEC60703-2-50 type B1.3/B6.a1 industry standards. -
LSZH Cable Jacket
Housed in a Low-Smoke Zero-Halogen (LSZH) flame-retardant jacket, the OS2 fiber cable emits low smoke and toxic fumes when exposed to extreme heat or in the event of a fire. This enables safer cable installations in areas with poor ventilation including some industrial settings, self-contained environments such as trains and aircraft, as well as residential settings where compliance with building codes must be considered. Each OS2 fiber cable is individually tested for insertion loss performance and includes a test report, for guaranteed compatibility and 100% reliability.
- StarTech.com 50m (164ft) LC to SC (UPC) OS2 Single Mode Duplex Fiber Optic Cable, 9/125µm, Laser Optimized, 10G, Bend Insensitive, Low Insertion Loss - LSZH Fiber Patch Cord (SMLCSC-OS2-50M) - patch cable - 50 m - yellow
- Patch cable - OS1/OS2
- Technology
- Duplex fibre optic
- Type of Fibre Optics
- Singlemode
- Halogen-free, passive adapter, bend insensitive, low insertion loss, wavelength of 1260-1625 nm, colour coded connectors, Coarse Wavelength Division Multiplexing (CWDM) support, aramid fibre reinforced, bending radius 10mm, 0.3 dB insertion loss, 55 dB return loss, ceramic ferrule, up to 10 Gbps
- Length
- 50 m
- Diameter
- 2 mm
- Core / Cladding Diameter
- 9 / 125 micron
- Connector
- 2 x LC/UPC single-mode - male
- Connector (Second End)
- 2 x SC/UPC single-mode - male
- Yellow
- Limited lifetime warranty
- Network Cable Type
- Technology
- Singlemode
- Jacket Material
- Low Smoke Zero Halogen (LSZH)
- 9 / 125 micron
- Length
- 50 m
- Diameter
- 2 mm
- Yellow
- Connector
- EMI, WEEE, RoHS
- Shipping Width
- 25 cm
- Shipping Depth
- 25 cm
- Shipping Height
- 1.8 cm
- Shipping Weight
- 361.2 g
- -20 °C
- 60 °C
