Discover the StarTech.com 50ft (15.2m) USB-C to HDMI 2.0 Active Optical Cable, your solution for connecting USB-C enabled devices to HDMI displays with clarity and performance. This cable supports 4K 60Hz video, offering breathtaking visuals and vibrant colors for a viewing experience. With support for 7.1 channel Surround Sound, it delivers rich, detailed audio that complements the high-definition visuals perfectly.
Designed for durability and high performance, it features EMI protection, USB-powered operation, and an outer diameter of 4.5 mm with strain relief, ensuring a reliable connection and longevity. Whether for professional presentations, high-definition video streaming, or enhancing your home entertainment system, this cable provides the connectivity and quality you need. Its compliance with HDCP 1.2 and HDCP 1.4 standards ensures compatibility with a wide range of devices and content, making it a versatile addition to your tech toolkit.
High-definition visuals
Experience visual quality with 4K60Hz (3840 x 2160) support, ensuring vibrant, detailed images for an immersive viewing experience. With 10-bit and 8-bit deep color, enjoy a broader spectrum of colors, making every scene more lifelike. -
Advanced audio features
Elevate your auditory experience with 7.1 channel Surround Sound support, creating a rich, enveloping sound environment. Whether watching movies, gaming, or enjoying concerts, the audio quality will transport you to the heart of the action. -
Enhanced connectivity
Featuring DisplayPort Alternate Mode support and HDMI CEC support, this cable offers versatile connectivity options, allowing for seamless integration with a wide range of devices and enabling control of multiple devices with a single remote. -
Durable and reliable design
Constructed with a fiber multimode and shielded/fiber optic technology, this cable is designed for durability and high performance. The outer diameter of 4.5 mm and strain relief feature ensure it withstands daily wear and tear, providing a reliable connection. -
Comprehensive compatibility
Compliant with HDCP 1.2 and HDCP 1.4 standards, this cable ensures a secure, high-quality link between devices, supporting a wide range of content. The CL3 rated jacket makes it suitable for in-wall installation, offering flexibility in setup and use.
- StarTech.com 50ft (15.2m) USB-C to HDMI 2.0 Active Optical Cable, 4K 60Hz - HDMI cable - 15.2 m
- Cable
- HDMI cable
- Technology
- Shielded/fibre optic
- Length
- 15.2 m
- Black
- Connectors
- 24 pin USB-C - male (input)
- Connectors (Second End)
- HDMI - male (output) , USB (power only) - male
- OM3
- Active cable, Active Optical Cable (AOC), Unidirectional, 4K60Hz (3840 x 2160) support
- 3-year warranty
- Cable Type
- HDMI cable active, Active Optical Cable (AOC), Unidirectional, 4K60Hz (3840 x 2160) support
- Technology
- Jacket Material
- PVC
- OM3
- Length
- 15.2 m
- CL3 rated jacket, Audio Return Channel (ARC), HDMI CEC support (Consumer Electronics Control), HDR support, support HDR10, 4:4:4 Chroma Subsampling, TMDS support, strain relief, USB powered, 8 bit deep colour, 10 bit deep colour, outer diameter 4.5mm, DisplayPort Alternate Mode support, fibre multimode, 7.1 channel Surround Sound, EMI protection, wide screen support
- Black
Adapters & Converters
- OS Required
- Apple MacOS, Linux, Google Chrome OS, Windows
- Connectors
- 19 pin HDMI Type A - male (output) , 4 pin USB Type A (power only) - male
- RoHS, WEEE, HDCP 1.2, HDCP 1.4, CL3
- Shipping Width
- 22.4 cm
- Shipping Depth
- 23.4 cm
- Shipping Height
- 3.9 cm
- Shipping Weight
- 70 g
- Limited warranty - 3 years
StarTech.com 6 ft Black USB 2.0 Extension Cable A to A - M/F | In Stock | £4.27 |
StarTech.com 30ft USB-C to HDMI Cable (AOC) | In Stock | £137.57 |
