Power your USB Type-C devices, with reduced clutter. With up to 5A (100W) of power output, you can use this USB-C to USB-C cable to power and charge a USB-C laptop, such as your Apple MacBook Pro, MacBook or Chromebook Pixel, using a USB-C wall charger, car charger or power bank. Or, you can power your laptop from a USB-C docking station.
The 5A of Power Delivery lets you charge your mobile devices faster than with a regular USB-C 2.0 cable, which is perfect for people on the move. Decrease your charge times and make sure your mobile devices are ready, whenever you need them while you're on the road.
The short cable lets you set up in small offsite workspaces, or in a coffee shop or hotel room. You can connect a mobile device such as your phone or tablet to your laptop without excess cable getting in your way.
The USB Type-C cable has undergone rigorous compliance testing and is certified by USB-IF (USB Implementers Forum) to meet all USB 2.0 specifications. This includes all environmental, electrical and mechanical standards, which ensures a reliable and high-quality cable for all of your USB-C devices.
Reliable connectivity
This USB C to USB C cable ensures reliable connections between devices with its dual 24 pin USB-C male connectors, providing seamless data transfer and power delivery. -
Enhanced durability
The cable's double-shielded design features aluminum mylar foil and braid, offering protection against interference for clear signals and increased longevity. -
Efficient power delivery
Capable of delivering up to 100 watts of power, this cable provides rapid charging capabilities for various USB Type C devices, ensuring they remain powered and ready for use.
- StarTech.com USB C to USB C Cable - 1.5 ft / 0.5m - 5A PD - White - USB 2.0 - USB-IF Certified - USB Type C Cable - USB C Charging Cable (USB2C5C50CM) - USB-C cable - 24 pin USB-C to 24 pin USB-C - 50 cm
- USB-C cable
- Technology
- Double shielded
- Up to 100 Watts of power delivery
- Length
- 50 cm
- Connector
- 24 pin USB-C - male
- Connector (Second End)
- Rated Current
- 5 A
- Thunderbolt 3 / USB 2.0
- Black
- 2-year warranty
- USB-C cable
- Technology
- Double shielded
- Shielding Material
- Aluminum mylar foil with braid
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 24/26
- Rated Current
- 5 A
- Plated Connector
- Nickel
- Length
- 50 cm
- Black
- 23 g
- Connector
- Thunderbolt 3 / USB 2.0, RoHS, USB-IF, WEEE
- 2-year warranty
StarTech.com 4m USB 2.0 C Cable w/ PD (5A) | In Stock | £15.43 |
StarTech.com 3m 10ft USB C Cable w/ 5A PD | In Stock | £18.64 |
StarTech.com 1m 3ft USB C Cable w/ 5A PD | In Stock | £10.20 |
StarTech.com USB 2.0 - C to C w/ 5A PD - 6 ft / 2m | In Stock | £14.97 |
StarTech.com 2m USB 2.0 Certified Power Delivery(5A) C to C White Cable | In Stock | £13.77 |
StarTech.com 4m USB 2.0 Power Delivery(5A) C to C White Cable - M/M | In Stock | £13.90 |
StarTech.com 50cm USB 2.0 Power Delivery(5A) C to C Cable - M/M | In Stock | £9.63 |
