StarTech.com 50cm Premium Certified HDMI
Quicklinx: GR60WS00 Mfr#: HDMMV50CM
Length: 50cm
£9.74 ex VAT
£11.68 inc VAT
This 20 in. (50 cm) Premium High-Speed HDMI 2.0 Certified Cable is built to endure cable stress. Tested to endure strenuous wear and tear, this durable cable is a must-have for both business and consumer applications.
  • Experience Expanded Bandwidth With HDMI 2.0
    This high performance 4K cable supports resolutions of up to 4K at 60Hz (3840x2160p) and bandwidths of up to 18Gbps. It also supports HDR10 (High Dynamic Range) and Dolby Vision, for higher contrast ratios and vivid colors. In addition, ARC (Audio Return Channel) features up to 32 uncompressed 5.1 and 7.1 digital audio channels to support DTS-HD Master Audio ; DTS:X ; Dolby TrueHD, and Dolby Atmos ; for high quality sound. With high resolutions, increased speeds, sharper images, and crystal-clear audio, you can expect enhanced audio/video experience. The cable will provide the very best HDMI 4K performance. It's the perfect cable for creating the ultimate home theater or for providing lifelike digital signage. This cable works with all 4K compatible devices and is also backward compatible with previous HDMI specifications.
  • HDMI Premium Certified Cable
    The cable has undergone rigorous compliance testing and is certified by an HDMI Authorized Test Center, to ensure it supports high-bandwidth enabled features. An EMI test is performed to ensure minimal interference to surrounding wireless signals.
  • Cable Key Features
    Aluminum-mylar foil with braided shielding improves Electromagnetic Interference (EMI) protection. Durable and supple TPE jacket and strain reliefs (TPE is non-toxic & halogen free for environmental sustainability).
  • Connector Key Features
    Corrosion-resistant gold-plated connectors ensure premium video quality and enhanced reliability. Tested to withstand 10 000+ insertions. HDMMV50CM is backed by StarTech.com's Lifetime Warranty.
Startech 20in (0.5m) Premium Certified HDMI 2.0 Cable with Ethernet, High-Speed Ultra HD 4K 60Hz HDMI Cable HDR10, ARC, HDMI Cord For Ultra HD Monitors, TVs, Displays, w/ TPE Jacket - Durable HDMI Video Cable (HDMMV50CM) - HDMI cable with Ethernet - 50 cm
Cable
Premium High Speed - HDMI cable with Ethernet
Shielded
American Wire Gauge (AWG)
30
Cable Length
50 cm
Grey, black
Connector
HDMI - male
Connector (Second End)
HDMI - male
Passive cable, 4K60Hz (3840 x 2160) support
Cable Type
Premium High Speed - HDMI cable with Ethernet passive, 4K60Hz (3840 x 2160) support
Shielded
30
Jacket Material
Thermoplastic elastomer (TPE)
Shielding Material
Cable Length
50 cm
Plated Connector
Gold
Audio Return Channel (ARC), Dolby TrueHD support, Dolby DTS-HD Master Audio support, Dolby Atmos support, support HDR10, Dolby DTS 5.1 support, Dolby DTS:X support, 3D ready, colourimetry BT.2020 support, 18 Gbps data rate, Dolby DTS 7.1 support, strain relief, outer diameter 6mm
Grey, black
Connector
19 pin HDMI Type A - male
RoHS, WEEE, EMI
Shipping Width
22 cm
Shipping Depth
20 cm
Shipping Height
3 cm
Shipping Weight
75 g
Limited warranty - lifetime
GR60 StarTech.com 13ft/4m Premium Certified HDMI 2.0 Cable In Stock £17.09
GR60 StarTech.com 16ft/5m Premium Certified HDMI 2.0 Cable In Stock £17.97
Length: 50cm
