Connect a SAS Controller to 4 SAS drives. The SAS808782P50 Mini SAS to SAS cable (50cm) features one 36-pin SFF-8087 plug, which fans out to four individual 29-pin SFF-8482 receptacles, providing a reliable solution for connecting multiple SAS HDD drives (with both data and power) to a single mini SAS controller connection.
This high quality internal Mini SAS to SAS cable is designed for long-lasting dependability and reliable performance.
 - StarTech.com 50cm Internal Serial Attached SCSI Mini SAS Cable - SFF8087 to 4x SFF8482 - Internal Mini SAS Cable (SAS808782P50) - SAS internal cable - 50 cm
- Interface Speed
 - SAS 6Gbit/s
- Length
 - 50 cm
- Connectors
 - 36 pin 4i Mini MultiLane SAS (SFF-8087) - plug
- Connectors (Second End)
 - 4 x 29 pin internal SAS (SFF-8482) - receptacle , 4 x 15 pin Serial ATA power - plug
 - Red
 - Limited lifetime warranty
- Storage Cable Type
- Interface Speed
 - SAS 6Gbit/s
- American Wire Gauge (AWG)
 - 30
- Length
 - 50 cm
 - Red
- Connectors
 - RoHS
